By DeeDeee
By Danster75
Hi all,
I'm Danny and have a problem with my LG OLED65C8;
since a few months when playing movies, either from my Syno NAS or just plain USB, subtitles are being displayed double (over or above eachother) or are displayed for sometimes minutes after the sentence's been spoken. The videofiles haven't got any hardcoded subs but either subs included in the mkv container or as separate srt of ssa file. Disabling subs removes the display of subs, enabling subs results in double or persistent subs.
Subtitles have been disabled in the accessability menu, factory reset did not help.
I searched but as far as I can see this problem has not been discussed yet, also googled and never came across this problem. Perhaps someone here can help?
Kind regards, Danny
SOLUTION, for me at least:
I used ColorControl to reboot the TV. It's weird that a factory reset did not work but a simple reboot did.
By Trevin
By Citron2010
Hi, I have an LG 43UN71006LB with OS v4.50.53 (latest)
I thought I'd test this on my TV and it works very well. I've even set "routines" on Alexa so that saying "Alexa, BBC 1" is a shortcut for "Alex, change the channel on LGTV to 101" etc.
Also tried:
"Alexa, enable Sound Share on LGTV" - "that command doesn't work on device LGTV"
Anyone have any ideas?
- 1,550 views
- 1 reply
- 4,811 views
- 3 answers
- 7,373 views
Disney plus app, where is it? 1 2 3
By ReneVlEugel,
- not installing
- projector sw version 3.00.03
- (and 5 more)
- 77 replies
- 25,424 views
இரவிசங்கர்
LG 43UP75 - Alexa showing US site URL to login. Unable to login with my Amazon prime account
LG channel app not found..
Media player is not supporting audio with mkv files.
