Using the magic remote with Google assistant to operate wi-fi socket outlet
By agus
By RJ Fischer
By hollean
By JamieG
- 3 replies
- 1,478 views
- 694 views
- 0 replies
- 653 views
- 1 answer
- 3,115 views
fade2gray
I can turn the Wi-Fi socket on and off using the Google Home app on my mobile phone by using the voice command "turn socket on" and "turn socket off".
Using the same commands with Google assistant on the magic remote, will turn the socket on but will not turn it off.
Any advice please?
