Keyboard in youtube
By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
By JonoW
Raju S B
Hi In the present keyboard available for YouTube on lg nano tv iam unable to use Capital letters and also special characters.
Is there any way to change to a better keyboard.
