Certificate is invalid. Please check time and date.
    • By PVD
    • By Jaswinder Sandhu
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By u84six
    • By Gene680
      It turns my channel off at random times exactly 11 minutes after the hour. I checked and double checked the settings looking for timers, etc. any fixes that I’m missing?  It’s when I’m streaming on Sling.
