By
akhil7j
DawoodCon
Good day
i need some assistance please.
i came home and switched on my tv and non of my apps want to work and when i went to the LG content store it gave me an error:109 and it states that I have to contact my content provider.
please assist me anyone please.zill be very greatfull if someone can help me.
many thanks
Mr D
