By JamieG
By mr.porter
Hello
Question about new LG WebOS tv's, anyone noticed when pausing live TV ( live playback) on Webos 5.3 ( GX ) that recording is reset when changing channels.
Meaning if you have paused tv and then changed the channel the playback recording is lost / reset to 0 minutes.
I've have two LG tv's before the GX that didn't do this current this have one.
By Trung Hiếu Trần
Specs: LG OLED 55C3
Router speed: 250mbps
System: webOS 2.3
Any ideas on how to fix it?
By Jonatan de la Torre Gómez
By Birkso
Have an LG55Nano which works well apart from when on specific BBC shows whereby whenever there is a switch if camera, say from contestants to host and vice versa, there is an extremely annoying flickering motion that takes place. May sound petty but any visitors comment on how distracting it can be.
Happens constantly on Richard Osmans House of Games, Impossible, Pointless and similar BBC programmes. Reported it but was told I had to get video clips for them to assist despite it being less than a year old. Life's too short. Any advice very welcome.
- 0 replies
- 1,871 views
- 0 replies
- 2,130 views
- 7 answers
- 3,445 views
How can I switch between audio tracks and subtitle languages in Smart Share (webOS 2)
By David Póka,
- AudioSmart Share
- Subtitle
- (and 1 more)
- 0 replies
- 5,149 views
