PreCentral: Review: Mugen 1400 mAh extended SL battery for Pre3
Anyone who has used a webOS phone for any period of time knows that battery life is not one of the strongest features of those phones. While it has gotten significantly better from when the original Pre was first released in 2009, it's still a difficult task to make it through a full day with any type of moderate usage. For Pre, Pre Plus, or
owners, the good news was that you could use spare batteries from any of those phones interchangeably or purchase spare stock or extended batteries from places such as the .
With the official limited release of the in Europe and the slew of AT&T (and a few Verizon) phones making their way to eBay, we found ourselves in a bit of a quandary: the only way to get a spare battery for those phones was to buy an extra Pre3. Not exactly an inexpensive (or efficient) proposition. And if you didn’t want to spend the hundreds of dollars on another Pre3 just for its battery, what would happen if/when the battery stopped working after extended usage, shorted out, or gets trashed?
Seeing a potential business opportunity, Mugen Power Batteries (who previously made extended batteries for both the Pre and Pixi) created their own a late last year to gague interested in extended batteries for the Pre3. Within just a few hours of opening the poll, Mugen announced that they received enough feedback to justify development of Pre3 batteries. Pre-orders were opened in December for a and a , the latter of which comes with a larger back cover for the Pre3. As compared to the stock Pre3 battery that clocks in at 1230 mAh, these batteries should provide an extra 14% or 128% of battery life before your phone needs to be plugged back in.
_ahdmdx-fZo
    • By Harald Dunkel
      Since 4 weeks my TV (OLED55BX9LB) nags me I should replace the batteries in the magic remote. Is there some way to disable this annoyance? The batteries are still fine.
    • By Peter94
      I use BT Headphone with LG OLED C1 TV Webos 6.  It would be nice if I could also see its battery level next to volume level on the screen
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
