PreCentral: How to install homebrew apps on your TouchPad or webOS smartphone
Ready to jump into the wide world of homebrew on your TouchPad, Pre, or Veer? Alright! Here's what you need:
  • Your webOS tablet or smartphone
  • A computer, Mac or PC, connected to the internet
  • A Micro-USB cable to connect the webOS device to your computer (you can use the cable that came with the device, but any Micro-USB cable will do)
  • A stiff drink (this isn't required, but you'll deserve one for being awesome enough to be doing homebrew)
Got that? Okay, time for some clarifications. webOS devices do not need to be "rooted" - they come from the factory open enough that special tools aren't needed to install apps outside of the App Catalog or gain access to the operating system. The process of getting a homebrew installer set-up is relatively straight-forward and doesn't involve anything scary or potentially warranty voiding (there are potentially warranty-voiding things you can do after that, but everything described in this how-to is perfectly acceptable).
zUKW_IL-qLU
    • By David Daul
    • By anna groove
    • By Pranay Mokida
    • By MNHL
