By
Alex
In hybrid work environments, this technology can make the difference between effective and ineffective collaboration by providing an easy-to-see snapshot of data, no matter where
the viewer sits.
The LG ProBeam is a powerful, user-friendly projector, generating some of the most accurate images I’ve seen in years.
A consumer-grade device, the LG ProBeam delivers professional-level projection capable of rendering 3840x2160 4K ultrahigh-definition images. It can project 8.3 million pixels at a native aspect ratio of 16:9, which makes the ProBeam an incredibly sharp projector with color accuracy on par with agency needs.
Source:
RLR
How can I clear the LG TV (UM7600PLB / os. 05.10.25) cache?
I don't mean any particular app or browser but the whole TV cache. The cache contains incorrect data.
The data is cached because the factory settings do not help. I know you have to have the kind of script that does it.
