How can I clear the LG TV (UM7600PLB / os. 05.10.25) cache?
I don't mean any particular app or browser but the whole TV cache. The cache contains incorrect data.
The data is cached because the factory settings do not help. I know you have to have the kind of script that does it.
3 answers to this question
I got tired of trying many kinds of resets.
I bought a Sony TV and it has a function to clear the cache (one click). And much clearer menus. LG has many different looking menus and finding the right app is hard. For example, try to find text-TV.
I’m pretty sure there’s a trick that can be used to empty the cache, but it’s a hidden command, and LG won’t tell us that.
    • By Ingemar Olsson
      Web OS 4.30. Home screen show history of  APPs video, foto and music above APPs before selected.
      How clear history?
      MENU:General->AI->AI recommendations-> CLEAR USER DATA
      Does not do the job. Only clear Last used APPs.
      Help?
      Regards Ingemar
    • By Alex
      the viewer sits.
      Source:
    • By Steve Bowes-Phipps
      My LG TV works great with terrestrial TV (I have no sound bar) but when I stream content from, say NowTV, iPlayer, etc, particularly films, the background sounds and music are louder than the speech, making the viewing experience quite frustrating.
      Is there something I can do to improve this?  I am already on Clear Speech in the settings.  I don't mind if it's a sound bar or audio streamer I need to get, but I want to know why it only affects streamed content and what I can do about it?
      Many thanks in advance for your help forumites!
      Steve
    • By RLR
    • By Vmjoao
      Our app has a MSE player that just hangs forever when trying to play Clear content after DRM content (widevine).
      Every other scenario works:
      - Clear after clear
      - DRM after DRM
      - DRM after clear
      This is only happening in webos 4 (LM18A), any clue?
