Emulator
By Hùng Mạnh
Hi everyone,
I was trying to install an environment to develop.
But I can't run the emulator (Version 5).
I always get this error prompt.
Please help me. Thank you.
By Mohannad Hanafi
I installed webOS TV Emulator v6.0.0 and when I run it, it shows a black screen like this
It's running on Oracle VM VirtualBox.
By Webosdev
I walked through this guide
but I got the first problem that the emulator didn't run probably it just shows a blank black page, I tried to launch the application installed from the App Manager, but nothing.
By Hazem Huzayen
I have been trying to install the Emulator for webOS version 2.0.0 from the Component Manager for webOS SDK but the install button turns to waiting and back to install without installing anything other emulator versions install fine
is there a way to get the emulator online or a way to fix this issue ?
By silas
I did try to uninstall and install everything 3 times
link hidden, please login to view ) CLI ok , generate ok , package ok but cannot install app
WEBOS Emulator error:
error: VERR_INVALID_NAME
virtual box error :
The virtual machine 'LG webOS TV Emulator 6.0.0' has terminated unexpectedly during startup with exit code 1 (0x1). More details may be available in 'C:\webOS_TV_SDK\Emulator\v6.0.0\Logs\VBoxHardening.log'.
1de8.1a7c: Log file opened: 6.1.22r144080 g_hStartupLog=0000000000000074 g_uNtVerCombined=0xa04a6300
1de8.1a7c: \SystemRoot\System32\ntdll.dll:
1de8.1a7c: CreationTime: 2021-07-15T16:55:03.705827700Z
1de8.1a7c: LastWriteTime: 2021-07-15T16:55:04.040636700Z
1de8.1a7c: ChangeTime: 2021-07-16T02:15:16.623090700Z
1de8.1a7c: FileAttributes: 0x20
1de8.1a7c: Size: 0x1ee508
1de8.1a7c: NT Headers: 0xe8
1de8.1a7c: Timestamp: 0xe7a22463
1de8.1a7c: Machine: 0x8664 - amd64
1de8.1a7c: Image Version: 10.0
1de8.1a7c: SizeOfImage: 0x1f5000 (2052096)
1de8.1a7c: Resource Dir: 0x184000 LB 0x6fdc8
1de8.1a7c: [Version info resource found at 0xd8! (ID/Name: 0x1; SubID/SubName: 0x409)]
1de8.1a7c: [Raw version resource data: 0x1840f0 LB 0x380, codepage 0x0 (reserved 0x0)]
1de8.1a7c: ProductName: Microsoft® Windows® Operating System
1de8.1a7c: ProductVersion: 10.0.19041.1110
1de8.1a7c: FileVersion: 10.0.19041.1110 (WinBuild.160101.0800)
1de8.1a7c: FileDescription: NT Layer DLL
1de8.1a7c: \SystemRoot\System32\kernel32.dll:
1de8.1a7c: CreationTime: 2021-06-09T17:27:35.972166800Z
1de8.1a7c: LastWriteTime: 2021-06-09T17:27:36.050283600Z
1de8.1a7c: ChangeTime: 2021-07-16T02:15:15.263822100Z
1de8.1a7c: Size: 0xbac20
1de8.1a7c: Timestamp: 0x92f57b1a
1de8.1a7c: SizeOfImage: 0xbd000 (774144)
1de8.1a7c: Resource Dir: 0xbb000 LB 0x520
1de8.1a7c: [Version info resource found at 0x90! (ID/Name: 0x1; SubID/SubName: 0x409)]
1de8.1a7c: [Raw version resource data: 0xbb0b0 LB 0x3a4, codepage 0x0 (reserved 0x0)]
1de8.1a7c: ProductVersion: 10.0.19041.1023
1de8.1a7c: FileVersion: 10.0.19041.1023 (WinBuild.160101.0800)
1de8.1a7c: FileDescription: Windows NT BASE API Client DLL
1de8.1a7c: \SystemRoot\System32\KernelBase.dll:
1de8.1a7c: CreationTime: 2021-07-15T16:55:06.356316100Z
1de8.1a7c: LastWriteTime: 2021-07-15T16:55:06.673145900Z
1de8.1a7c: ChangeTime: 2021-07-16T02:15:16.404355200Z
1de8.1a7c: Size: 0x2c9b88
1de8.1a7c: NT Headers: 0xf8
1de8.1a7c: Timestamp: 0x4809adf2
1de8.1a7c: SizeOfImage: 0x2c9000 (2920448)
1de8.1a7c: Resource Dir: 0x2a0000 LB 0x548
1de8.1a7c: [Raw version resource data: 0x2a00b0 LB 0x3bc, codepage 0x0 (reserved 0x0)]
1de8.1a7c: \SystemRoot\System32\apisetschema.dll:
1de8.1a7c: CreationTime: 2019-12-07T09:08:13.518339400Z
1de8.1a7c: LastWriteTime: 2019-12-07T09:08:13.518339400Z
1de8.1a7c: ChangeTime: 2021-07-15T17:02:13.774809200Z
1de8.1a7c: Size: 0x1f538
1de8.1a7c: NT Headers: 0xd0
1de8.1a7c: Timestamp: 0x31288ce0
1de8.1a7c: SizeOfImage: 0x20000 (131072)
1de8.1a7c: Resource Dir: 0x1f000 LB 0x408
1de8.1a7c: [Version info resource found at 0x48! (ID/Name: 0x1; SubID/SubName: 0x409)]
1de8.1a7c: [Raw version resource data: 0x1f060 LB 0x3a8, codepage 0x0 (reserved 0x0)]
1de8.1a7c: FileVersion: 10.0.19041.1 (WinBuild.160101.0800)
1de8.1a7c: FileDescription: ApiSet Schema DLL
1de8.1a7c: NtOpenDirectoryObject failed on \Driver: 0xc0000022
1de8.1a7c: supR3HardenedWinFindAdversaries: 0x2
1de8.1a7c: \SystemRoot\System32\drivers\symevent64x86.sys:
1de8.1a7c: CreationTime: 2021-07-21T11:17:33.161924400Z
1de8.1a7c: LastWriteTime: 2021-07-21T11:17:32.661958000Z
1de8.1a7c: ChangeTime: 2021-07-23T02:37:42.574820400Z
1de8.1a7c: Size: 0x16be0
1de8.1a7c: NT Headers: 0xf0
1de8.1a7c: Timestamp: 0x60921256
1de8.1a7c: Image Version: 6.3
1de8.1a7c: SizeOfImage: 0x21000 (135168)
1de8.1a7c: Resource Dir: 0x1f000 LB 0x3cc
1de8.1a7c: [Raw version resource data: 0x1f0b8 LB 0x314, codepage 0x4e4 (reserved 0x0)]
1de8.1a7c: ProductName: SYMEVENT
1de8.1a7c: ProductVersion: 14.0.7.121
1de8.1a7c: FileVersion: 14.0.7.121
1de8.1a7c: FileDescription: Symantec Event Library
1de8.1a7c: supR3HardenedWinInitAppBin(0x0): '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox'
1de8.1a7c: Calling main()
1de8.1a7c: SUPR3HardenedMain: pszProgName=VirtualBoxVM fFlags=0x2
1de8.1a7c: supR3HardenedWinInitAppBin(0x2): '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox'
1de8.1a7c: SUPR3HardenedMain: Respawn #1
1de8.1a7c: System32: \Device\HarddiskVolume5\Windows\System32
1de8.1a7c: WinSxS: \Device\HarddiskVolume5\Windows\WinSxS
1de8.1a7c: KnownDllPath: C:\WINDOWS\System32
1de8.1a7c: supR3HardenedWinInit: Performing a limited self purification...
1de8.1a7c: supHardNtVpScanVirtualMemory: enmKind=SELF_PURIFICATION
1de8.1a7c: *0000000000000000-000000000026ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000270000-000000000027ffff 0x0004/0x0004 0x0040000
1de8.1a7c: 0000000000280000-000000000028ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000290000-00000000002acfff 0x0002/0x0002 0x0040000
1de8.1a7c: 00000000002ad000-00000000002affff 0x0001/0x0000 0x0000000
1de8.1a7c: *00000000002b0000-0000000000360fff 0x0000/0x0004 0x0020000
1de8.1a7c: 0000000000361000-0000000000363fff 0x0104/0x0004 0x0020000
1de8.1a7c: 0000000000364000-00000000003affff 0x0004/0x0004 0x0020000
1de8.1a7c: *00000000003b0000-00000000003b3fff 0x0002/0x0002 0x0040000
1de8.1a7c: 00000000003b4000-00000000003bffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00000000003c0000-00000000003c1fff 0x0004/0x0004 0x0020000
1de8.1a7c: 00000000003c2000-00000000003cffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00000000003d0000-00000000003d1fff 0x0004/0x0004 0x0020000
1de8.1a7c: 00000000003d2000-00000000003e9fff 0x0000/0x0004 0x0020000
1de8.1a7c: 00000000003ea000-00000000003fffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000400000-00000000005ecfff 0x0000/0x0004 0x0020000
1de8.1a7c: 00000000005ed000-00000000005effff 0x0004/0x0004 0x0020000
1de8.1a7c: 00000000005f0000-00000000005fffff 0x0000/0x0004 0x0020000
1de8.1a7c: 0000000000600000-000000000062ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000630000-000000000063efff 0x0004/0x0004 0x0020000
1de8.1a7c: 000000000063f000-000000000063ffff 0x0000/0x0004 0x0020000
1de8.1a7c: 0000000000640000-00000000006affff 0x0001/0x0000 0x0000000
1de8.1a7c: *00000000006b0000-00000000006b4fff 0x0004/0x0004 0x0020000
1de8.1a7c: 00000000006b5000-00000000007affff 0x0000/0x0004 0x0020000
1de8.1a7c: *00000000007b0000-0000000000878fff 0x0002/0x0002 0x0040000
1de8.1a7c: 0000000000879000-000000000087ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000880000-0000000000881fff 0x0000/0x0004 0x0020000
1de8.1a7c: 0000000000882000-0000000000a77fff 0x0004/0x0004 0x0020000
1de8.1a7c: 0000000000a78000-0000000000a78fff 0x0000/0x0004 0x0020000
1de8.1a7c: 0000000000a79000-0000000000a7ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000a80000-0000000000aa4fff 0x0004/0x0004 0x0020000
1de8.1a7c: 0000000000aa5000-0000000000b7ffff 0x0000/0x0004 0x0020000
1de8.1a7c: 0000000000b80000-000000007ffdffff 0x0001/0x0000 0x0000000
1de8.1a7c: *000000007ffe0000-000000007ffe0fff 0x0002/0x0002 0x0020000
1de8.1a7c: 000000007ffe1000-000000007ffeefff 0x0001/0x0000 0x0000000
1de8.1a7c: *000000007ffef000-000000007ffeffff 0x0002/0x0002 0x0020000
1de8.1a7c: 000000007fff0000-00007ff4213fffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00007ff421400000-00007ff421404fff 0x0002/0x0002 0x0040000
1de8.1a7c: 00007ff421405000-00007ff4214fffff 0x0000/0x0002 0x0040000
1de8.1a7c: *00007ff421500000-00007ff52151ffff 0x0000/0x0004 0x0020000
1de8.1a7c: *00007ff521520000-00007ff52351ffff 0x0000/0x0004 0x0020000
1de8.1a7c: 00007ff523520000-00007ff523520fff 0x0004/0x0004 0x0020000
1de8.1a7c: 00007ff523521000-00007ff52352ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00007ff523530000-00007ff523530fff 0x0002/0x0002 0x0040000
1de8.1a7c: 00007ff523531000-00007ff52353ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00007ff523540000-00007ff523552fff 0x0002/0x0002 0x0040000
1de8.1a7c: 00007ff523553000-00007ff6ac71ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00007ff6ac720000-00007ff6ac720fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac721000-00007ff6ac797fff 0x0020/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac798000-00007ff6ac798fff 0x0080/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac799000-00007ff6ac7e1fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7e2000-00007ff6ac7e4fff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7e5000-00007ff6ac7e7fff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7e8000-00007ff6ac7eafff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7eb000-00007ff6ac7ebfff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7ec000-00007ff6ac7edfff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7ee000-00007ff6ac7eefff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7ef000-00007ff6ac837fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac838000-00007ffa3ccbffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00007ffa3ccc0000-00007ffa3ccc0fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\KernelBase.dll
1de8.1a7c: 00007ffa3ccc1000-00007ffa3cdd2fff 0x0020/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\KernelBase.dll
1de8.1a7c: 00007ffa3cdd3000-00007ffa3cf4afff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\KernelBase.dll
1de8.1a7c: 00007ffa3cf4b000-00007ffa3cf4efff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\KernelBase.dll
1de8.1a7c: 00007ffa3cf4f000-00007ffa3cf4ffff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\KernelBase.dll
1de8.1a7c: 00007ffa3cf50000-00007ffa3cf88fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\KernelBase.dll
1de8.1a7c: 00007ffa3cf89000-00007ffa3edfffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00007ffa3ee00000-00007ffa3ee00fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\kernel32.dll
1de8.1a7c: 00007ffa3ee01000-00007ffa3ee7efff 0x0020/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\kernel32.dll
1de8.1a7c: 00007ffa3ee7f000-00007ffa3eeb1fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\kernel32.dll
1de8.1a7c: 00007ffa3eeb2000-00007ffa3eeb2fff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\kernel32.dll
1de8.1a7c: 00007ffa3eeb3000-00007ffa3eeb3fff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\kernel32.dll
1de8.1a7c: 00007ffa3eeb4000-00007ffa3eebcfff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\kernel32.dll
1de8.1a7c: 00007ffa3eebd000-00007ffa3f32ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00007ffa3f330000-00007ffa3f330fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f331000-00007ffa3f44bfff 0x0020/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f44c000-00007ffa3f493fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f494000-00007ffa3f494fff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f495000-00007ffa3f496fff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f497000-00007ffa3f49ffff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f4a0000-00007ffa3f524fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f525000-00007ffffffeffff 0x0001/0x0000 0x0000000
1de8.1a7c: kernel32.dll: timestamp 0x92f57b1a (rc=VINF_SUCCESS)
1de8.1a7c: kernelbase.dll: timestamp 0x4809adf2 (rc=VINF_SUCCESS)
1de8.1a7c: VirtualBoxVM.exe: timestamp 0x60898c77 (rc=VINF_SUCCESS)
1de8.1a7c: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe: Signature #1/2: info status: 24202
1de8.1a7c: '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe' has no imports
1de8.1a7c: '\Device\HarddiskVolume5\Windows\System32\ntdll.dll' has no imports
1de8.1a7c: supR3HardenedWinInit: SUPHARDNTVPKIND_SELF_PURIFICATION_LIMITED -> VINF_SUCCESS, cFixes=0
1de8.1a7c: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe)
1de8.1a7c: supR3HardNtEnableThreadCreationEx:
1de8.1a7c: supR3HardNtDisableThreadCreation: pvLdrInitThunk=00007ffa3f3a4b10 pvNtTerminateThread=00007ffa3f3cd870
1de8.1a7c: supR3HardenedWinDoReSpawn(1): New child 3c7c.2ad0 [kernel32].
1de8.1a7c: supR3HardNtChildGatherData: PebBaseAddress=0000000000462000 cbPeb=0x388
1de8.1a7c: supR3HardNtPuChFindNtdll: uNtDllParentAddr=00007ffa3f330000 uNtDllChildAddr=00007ffa3f330000
1de8.1a7c: supR3HardenedWinSetupChildInit: uLdrInitThunk=00007ffa3f3a4b10
1de8.1a7c: supR3HardenedWinSetupChildInit: Initial context:
rax=0000000000000000 rbx=0000000000000000 rcx=00007ff6ac727900 rdx=0000000000462000
rsi=0000000000000000 rdi=0000000000000000 r8 =0000000000000000 r9 =0000000000000000
r10=0000000000000000 r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000 P1=0000000000000000 P2=0000000000000000
rip=00007ffa3f382630 rsp=00000000006ff9a8 rbp=0000000000000000 ctxflags=0010001b
cs=0033 ss=002b ds=0000 es=0000 fs=0000 gs=0000 eflags=00000200 mxcrx=00001f80
P3=0000000000000000 P4=0000000000000000 P5=0000000000000000 P6=0000000000000000
dr0=0000000000000000 dr1=0000000000000000 dr2=0000000000000000 dr3=0000000000000000
dr6=0000000000000000 dr7=0000000000000000 vcr=0000000000000000 dcr=0000000000000000
lbt=0000000000000000 lbf=0000000000000000 lxt=0000000000000000 lxf=0000000000000000
1de8.1a7c: supR3HardenedWinSetupChildInit: Start child.
1de8.1a7c: supR3HardNtChildWaitFor: Found expected request 0 (PurifyChildAndCloseHandles) after 49 ms.
1de8.1a7c: supR3HardNtChildPurify: Startup delay kludge #1/0: 521 ms, 33 sleeps
1de8.1a7c: supHardNtVpScanVirtualMemory: enmKind=CHILD_PURIFICATION
1de8.1a7c: *0000000000000000-000000000033ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000340000-000000000035ffff 0x0004/0x0004 0x0020000
1de8.1a7c: *0000000000360000-000000000037cfff 0x0002/0x0002 0x0040000
1de8.1a7c: 000000000037d000-000000000037ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000380000-0000000000383fff 0x0002/0x0002 0x0040000
1de8.1a7c: 0000000000384000-000000000038ffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000390000-0000000000391fff 0x0004/0x0004 0x0020000
1de8.1a7c: 0000000000392000-00000000003fffff 0x0001/0x0000 0x0000000
1de8.1a7c: *0000000000400000-0000000000461fff 0x0000/0x0004 0x0020000
1de8.1a7c: 0000000000462000-0000000000464fff 0x0004/0x0004 0x0020000
1de8.1a7c: 0000000000465000-00000000005fffff 0x0000/0x0004 0x0020000
1de8.1a7c: *0000000000600000-00000000006fafff 0x0000/0x0004 0x0020000
1de8.1a7c: 00000000006fb000-00000000006fdfff 0x0104/0x0004 0x0020000
1de8.1a7c: 00000000006fe000-00000000006fffff 0x0004/0x0004 0x0020000
1de8.1a7c: 0000000000700000-000000007ffdffff 0x0001/0x0000 0x0000000
1de8.1a7c: 000000007fff0000-00007ff5326cffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00007ff5326d0000-00007ff5326d0fff 0x0002/0x0002 0x0040000
1de8.1a7c: 00007ff5326d1000-00007ff5326dffff 0x0001/0x0000 0x0000000
1de8.1a7c: *00007ff5326e0000-00007ff5326f2fff 0x0002/0x0002 0x0040000
1de8.1a7c: 00007ff5326f3000-00007ff6ac71ffff 0x0001/0x0000 0x0000000
1de8.1a7c: 00007ff6ac7e2000-00007ff6ac7e2fff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7e3000-00007ff6ac7e3fff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7e4000-00007ff6ac7e8fff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7e9000-00007ff6ac7e9fff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7ea000-00007ff6ac7eafff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac7eb000-00007ff6ac7eefff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
1de8.1a7c: 00007ff6ac838000-00007ffa3f32ffff 0x0001/0x0000 0x0000000
1de8.1a7c: 00007ffa3f494000-00007ffa3f499fff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f49a000-00007ffa3f49afff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f49b000-00007ffa3f49ffff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f4a0000-00007ffa3f4aefff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f4af000-00007ffa3f4affff 0x0004/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f4b0000-00007ffa3f4b2fff 0x0008/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: 00007ffa3f4b3000-00007ffa3f524fff 0x0002/0x0080 0x1000000 \Device\HarddiskVolume5\Windows\System32\ntdll.dll
1de8.1a7c: supR3HardNtChildPurify: Done after 528 ms and 0 fixes (loop #0).
3c7c.2ad0: Log file opened: 6.1.22r144080 g_hStartupLog=0000000000000004 g_uNtVerCombined=0xa04a6300
3c7c.2ad0: supR3HardenedVmProcessInit: uNtDllAddr=00007ffa3f330000 g_uNtVerCombined=0xa04a6300 (stack ~00000000006ff438)
3c7c.2ad0: ntdll.dll: timestamp 0xe7a22463 (rc=VINF_SUCCESS)
3c7c.2ad0: New simple heap: #1 0000000000800000 LB 0x400000 (for 2052096 allocation)
3c7c.2ad0: supR3HardenedWinInitAppBin(0x0): '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox'
3c7c.2ad0: System32: \Device\HarddiskVolume5\Windows\System32
3c7c.2ad0: WinSxS: \Device\HarddiskVolume5\Windows\WinSxS
3c7c.2ad0: KnownDllPath: C:\WINDOWS\System32
3c7c.2ad0: supR3HardenedVmProcessInit: Opening vboxdrv stub...
3c7c.2ad0: supR3HardenedVmProcessInit: Restoring LdrInitializeThunk...
3c7c.2ad0: supR3HardenedVmProcessInit: Returning to LdrInitializeThunk...
3c7c.2ad0: Registered Dll notification callback with NTDLL.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\kernel32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\kernel32.dll
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\KERNEL32.DLL (Input=KERNEL32.DLL, rcNtResolve=0xc0150008) *pfFlags=0xffffffff pwszSearchPath=0000000000004001:<flags> [calling]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3ccc0000 LB 0x002c9000 C:\WINDOWS\System32\KERNELBASE.dll [fFlags=0x0]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\KernelBase.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\KernelBase.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3ee00000 LB 0x000bd000 C:\WINDOWS\System32\KERNEL32.DLL [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\kernel32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3ee00000 'C:\WINDOWS\System32\KERNEL32.DLL'
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ff6ac720000 LB 0x00118000 C:\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe [fFlags=0x0]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe: Signature #1/2: info status: 24202
3c7c.2ad0: '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe' has no imports
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
3c7c.2ad0: supR3HardNtDisableThreadCreation: pvLdrInitThunk=00007ffa3f3a4b10 pvNtTerminateThread=00007ffa3f3cd870
1de8.1a7c: supR3HardNtChildWaitFor: Found expected request 1 (CloseEvents) after 167 ms.
3c7c.2ad0: \SystemRoot\System32\ntdll.dll:
3c7c.2ad0: CreationTime: 2021-07-15T16:55:03.705827700Z
3c7c.2ad0: LastWriteTime: 2021-07-15T16:55:04.040636700Z
3c7c.2ad0: ChangeTime: 2021-07-16T02:15:16.623090700Z
3c7c.2ad0: FileAttributes: 0x20
3c7c.2ad0: Size: 0x1ee508
3c7c.2ad0: NT Headers: 0xe8
3c7c.2ad0: Timestamp: 0xe7a22463
3c7c.2ad0: Machine: 0x8664 - amd64
3c7c.2ad0: Image Version: 10.0
3c7c.2ad0: SizeOfImage: 0x1f5000 (2052096)
3c7c.2ad0: Resource Dir: 0x184000 LB 0x6fdc8
3c7c.2ad0: [Version info resource found at 0xd8! (ID/Name: 0x1; SubID/SubName: 0x409)]
3c7c.2ad0: [Raw version resource data: 0x1840f0 LB 0x380, codepage 0x0 (reserved 0x0)]
3c7c.2ad0: ProductName: Microsoft® Windows® Operating System
3c7c.2ad0: ProductVersion: 10.0.19041.1110
3c7c.2ad0: FileVersion: 10.0.19041.1110 (WinBuild.160101.0800)
3c7c.2ad0: FileDescription: NT Layer DLL
3c7c.2ad0: \SystemRoot\System32\kernel32.dll:
3c7c.2ad0: CreationTime: 2021-06-09T17:27:35.972166800Z
3c7c.2ad0: LastWriteTime: 2021-06-09T17:27:36.050283600Z
3c7c.2ad0: ChangeTime: 2021-07-16T02:15:15.263822100Z
3c7c.2ad0: Size: 0xbac20
3c7c.2ad0: Timestamp: 0x92f57b1a
3c7c.2ad0: SizeOfImage: 0xbd000 (774144)
3c7c.2ad0: Resource Dir: 0xbb000 LB 0x520
3c7c.2ad0: [Version info resource found at 0x90! (ID/Name: 0x1; SubID/SubName: 0x409)]
3c7c.2ad0: [Raw version resource data: 0xbb0b0 LB 0x3a4, codepage 0x0 (reserved 0x0)]
3c7c.2ad0: ProductVersion: 10.0.19041.1023
3c7c.2ad0: FileVersion: 10.0.19041.1023 (WinBuild.160101.0800)
3c7c.2ad0: FileDescription: Windows NT BASE API Client DLL
3c7c.2ad0: \SystemRoot\System32\KernelBase.dll:
3c7c.2ad0: CreationTime: 2021-07-15T16:55:06.356316100Z
3c7c.2ad0: LastWriteTime: 2021-07-15T16:55:06.673145900Z
3c7c.2ad0: ChangeTime: 2021-07-16T02:15:16.404355200Z
3c7c.2ad0: Size: 0x2c9b88
3c7c.2ad0: NT Headers: 0xf8
3c7c.2ad0: Timestamp: 0x4809adf2
3c7c.2ad0: SizeOfImage: 0x2c9000 (2920448)
3c7c.2ad0: Resource Dir: 0x2a0000 LB 0x548
3c7c.2ad0: [Raw version resource data: 0x2a00b0 LB 0x3bc, codepage 0x0 (reserved 0x0)]
3c7c.2ad0: \SystemRoot\System32\apisetschema.dll:
3c7c.2ad0: CreationTime: 2019-12-07T09:08:13.518339400Z
3c7c.2ad0: LastWriteTime: 2019-12-07T09:08:13.518339400Z
3c7c.2ad0: ChangeTime: 2021-07-15T17:02:13.774809200Z
3c7c.2ad0: Size: 0x1f538
3c7c.2ad0: NT Headers: 0xd0
3c7c.2ad0: Timestamp: 0x31288ce0
3c7c.2ad0: SizeOfImage: 0x20000 (131072)
3c7c.2ad0: Resource Dir: 0x1f000 LB 0x408
3c7c.2ad0: [Version info resource found at 0x48! (ID/Name: 0x1; SubID/SubName: 0x409)]
3c7c.2ad0: [Raw version resource data: 0x1f060 LB 0x3a8, codepage 0x0 (reserved 0x0)]
3c7c.2ad0: FileVersion: 10.0.19041.1 (WinBuild.160101.0800)
3c7c.2ad0: FileDescription: ApiSet Schema DLL
3c7c.2ad0: NtOpenDirectoryObject failed on \Driver: 0xc0000022
3c7c.2ad0: supR3HardenedWinFindAdversaries: 0x2
3c7c.2ad0: \SystemRoot\System32\drivers\symevent64x86.sys:
3c7c.2ad0: CreationTime: 2021-07-21T11:17:33.161924400Z
3c7c.2ad0: LastWriteTime: 2021-07-21T11:17:32.661958000Z
3c7c.2ad0: ChangeTime: 2021-07-23T02:37:42.574820400Z
3c7c.2ad0: Size: 0x16be0
3c7c.2ad0: NT Headers: 0xf0
3c7c.2ad0: Timestamp: 0x60921256
3c7c.2ad0: Image Version: 6.3
3c7c.2ad0: SizeOfImage: 0x21000 (135168)
3c7c.2ad0: Resource Dir: 0x1f000 LB 0x3cc
3c7c.2ad0: [Raw version resource data: 0x1f0b8 LB 0x314, codepage 0x4e4 (reserved 0x0)]
3c7c.2ad0: ProductName: SYMEVENT
3c7c.2ad0: ProductVersion: 14.0.7.121
3c7c.2ad0: FileVersion: 14.0.7.121
3c7c.2ad0: FileDescription: Symantec Event Library
3c7c.2ad0: Calling main()
3c7c.2ad0: SUPR3HardenedMain: pszProgName=VirtualBoxVM fFlags=0x2
3c7c.2ad0: supR3HardenedWinInitAppBin(0x2): '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox'
3c7c.2ad0: SUPR3HardenedMain: Respawn #2
3c7c.2ad0: supR3HardNtEnableThreadCreationEx:
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3eec0000 LB 0x0012a000 C:\WINDOWS\System32\RPCRT4.dll [fFlags=0x0]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\rpcrt4.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\rpcrt4.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3dca0000 LB 0x0009b000 C:\WINDOWS\System32\sechost.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #11 'rpcrt4.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\sechost.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\sechost.dll
3c7c.2ad0: '\Device\HarddiskVolume5\Windows\System32\ntdll.dll' has no imports
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\ntdll.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\ntdll.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'rpcrt4.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'rpcrt4.dll' -> '\Device\HarddiskVolume5\Windows\System32\rpcrt4.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\rpcrt4.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\ntdll.dll (Input=ntdll.dll, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000801:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3f330000 'C:\WINDOWS\System32\ntdll.dll'
3c7c.2ad0: Error -104 in supR3HardenedWinReSpawn! (enmWhat=5)
3c7c.2ad0: Error relaunching VirtualBox VM process: 5
Command line: '60eaff78-4bdd-042d-2e72-669728efd737-suplib-3rdchild --comment "LG webOS TV Emulator 6.0.0" --startvm 9e8b9f29-44b2-4b6e-3053-2058a70342cb --no-startvm-errormsgbox --sup-hardening-log=C:\webOS_TV_SDK\Emulator\v6.0.0\Logs\VBoxHardening.log'
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'opengl32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'uicommon.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #2 'vboxrt.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'msvcp100.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #4 'msvcr100.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #5 'qt5corevbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #6 'qt5guivbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #7 'qt5widgetsvbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #8 'qt5openglvbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #10 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #11 'ole32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #12 'oleaut32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #13 'winmm.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'winmm.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'winmm.dll' -> '\Device\HarddiskVolume5\Windows\System32\winmm.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'msvcrt.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\winmm.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\winmm.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'oleaut32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'oleaut32.dll' -> '\Device\HarddiskVolume5\Windows\System32\oleaut32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'msvcp_win.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #5 'combase.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #21 'rpcrt4.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\oleaut32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\oleaut32.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'ole32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'ole32.dll' -> '\Device\HarddiskVolume5\Windows\System32\ole32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #49 'gdi32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #50 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #51 'combase.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\ole32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\ole32.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'user32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'user32.dll' -> '\Device\HarddiskVolume5\Windows\System32\user32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'win32u.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #37 'gdi32.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\user32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\user32.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'qt5openglvbox.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'qt5openglvbox.dll' -> '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\qt5openglvbox.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5OpenGLVBox.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'qt5widgetsvbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'qt5guivbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #2 'qt5corevbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'msvcr100.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5OpenGLVBox.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5OpenGLVBox.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'qt5widgetsvbox.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'qt5widgetsvbox.dll' -> '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\qt5widgetsvbox.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5WidgetsVBox.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'gdi32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #2 'qt5guivbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'qt5corevbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #4 'shell32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #5 'msvcp100.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #6 'msvcr100.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5WidgetsVBox.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5WidgetsVBox.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'qt5guivbox.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'qt5guivbox.dll' -> '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\qt5guivbox.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5GuiVBox.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'ole32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'opengl32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #2 'gdi32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #4 'qt5corevbox.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5GuiVBox.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5GuiVBox.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'qt5corevbox.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'qt5corevbox.dll' -> '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\qt5corevbox.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5CoreVBox.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #2 'shell32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'ole32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #4 'advapi32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #5 'ws2_32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #6 'mpr.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #7 'msvcp100.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #8 'msvcr100.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5CoreVBox.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5CoreVBox.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'msvcr100.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'msvcr100.dll' -> '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcr100.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcr100.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcr100.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcr100.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'msvcp100.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'msvcp100.dll' -> '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcp100.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcp100.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'msvcr100.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcp100.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcp100.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'vboxrt.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'vboxrt.dll' -> '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\vboxrt.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VBoxRT.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'msvcp100.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'rpcrt4.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VBoxRT.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VBoxRT.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'uicommon.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'uicommon.dll' -> '\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\uicommon.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\UICommon.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'vboxrt.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'msvcr100.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'qt5guivbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #4 'qt5widgetsvbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #6 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #7 'advapi32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #8 'ole32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #9 'oleaut32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #10 'rpcrt4.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\UICommon.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\UICommon.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'opengl32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'opengl32.dll' -> '\Device\HarddiskVolume5\Windows\System32\opengl32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'msvcrt.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #2 'advapi32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #7 'gdi32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #8 'glu32.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 22900 (\Device\HarddiskVolume5\Windows\System32\opengl32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\opengl32.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'glu32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'glu32.dll' -> '\Device\HarddiskVolume5\Windows\System32\glu32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #2 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'opengl32.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 22900 (\Device\HarddiskVolume5\Windows\System32\glu32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\glu32.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'gdi32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'gdi32.dll' -> '\Device\HarddiskVolume5\Windows\System32\gdi32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #9 'win32u.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\gdi32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\gdi32.dll
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\user32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'advapi32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'advapi32.dll' -> '\Device\HarddiskVolume5\Windows\System32\advapi32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #6 'sechost.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #27 'rpcrt4.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\advapi32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\advapi32.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'msvcrt.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'msvcrt.dll' -> '\Device\HarddiskVolume5\Windows\System32\msvcrt.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\msvcrt.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\msvcrt.dll
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\oleaut32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\ole32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\advapi32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5WidgetsVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5GuiVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5CoreVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcr100.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VBoxRT.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'ws2_32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'ws2_32.dll' -> '\Device\HarddiskVolume5\Windows\System32\ws2_32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #26 'rpcrt4.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\ws2_32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\ws2_32.dll
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcp100.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'mpr.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'mpr.dll' -> '\Device\HarddiskVolume5\Windows\System32\mpr.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\mpr.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\mpr.dll
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\ws2_32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'shell32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'shell32.dll' -> '\Device\HarddiskVolume5\Windows\System32\shell32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #72 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #74 'gdi32.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\shell32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\shell32.dll
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\gdi32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\opengl32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\shell32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'win32u.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'win32u.dll' -> '\Device\HarddiskVolume5\Windows\System32\win32u.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: '\Device\HarddiskVolume5\Windows\System32\win32u.dll' has no imports
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\win32u.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\win32u.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'combase.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'combase.dll' -> '\Device\HarddiskVolume5\Windows\System32\combase.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\combase.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\combase.dll
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\combase.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'msvcp_win.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'msvcp_win.dll' -> '\Device\HarddiskVolume5\Windows\System32\msvcp_win.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\msvcp_win.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\msvcp_win.dll
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\msvcrt.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\msvcp_win.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'sechost.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'sechost.dll' -> '\Device\HarddiskVolume5\Windows\System32\sechost.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\sechost.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\win32u.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\Program Files\Oracle\VirtualBox\VirtualBoxVM.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000a01:<flags> [calling]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\opengl32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\UICommon.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VBoxRT.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcp100.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcr100.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5CoreVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5GuiVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5WidgetsVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5OpenGLVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\winmm.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\glu32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\mpr.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3e580000 LB 0x0009e000 C:\WINDOWS\System32\msvcrt.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\msvcrt.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3e620000 LB 0x000ac000 C:\WINDOWS\System32\ADVAPI32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\advapi32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3d2a0000 LB 0x00022000 C:\WINDOWS\System32\win32u.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\win32u.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3cf90000 LB 0x00100000 C:\WINDOWS\System32\ucrtbase.dll [fFlags=0x0]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\ucrtbase.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\ucrtbase.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3d0c0000 LB 0x0009d000 C:\WINDOWS\System32\msvcp_win.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\msvcp_win.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3cbb0000 LB 0x0010b000 C:\WINDOWS\System32\gdi32full.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #33 'gdi32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #35 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #36 'win32u.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\gdi32full.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\gdi32full.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3f110000 LB 0x0002a000 C:\WINDOWS\System32\GDI32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\gdi32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3ebe0000 LB 0x001a0000 C:\WINDOWS\System32\USER32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\user32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3ddb0000 LB 0x00355000 C:\WINDOWS\System32\combase.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\combase.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa306a0000 LB 0x0002c000 C:\WINDOWS\SYSTEM32\GLU32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\glu32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa19d50000 LB 0x00125000 C:\WINDOWS\SYSTEM32\OPENGL32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\opengl32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 0000000076030000 LB 0x000d2000 C:\Program Files\Oracle\VirtualBox\MSVCR100.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcr100.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00000000752f0000 LB 0x00098000 C:\Program Files\Oracle\VirtualBox\MSVCP100.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\msvcp100.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3e830000 LB 0x0006b000 C:\WINDOWS\System32\WS2_32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\ws2_32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ff9db4f0000 LB 0x005e2000 C:\Program Files\Oracle\VirtualBox\VBoxRT.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VBoxRT.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3d540000 LB 0x0073f000 C:\WINDOWS\System32\SHELL32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\shell32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3e700000 LB 0x0012a000 C:\WINDOWS\System32\ole32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\ole32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa2a2c0000 LB 0x0001d000 C:\WINDOWS\SYSTEM32\MPR.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\mpr.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 0000000074320000 LB 0x00565000 C:\Program Files\Oracle\VirtualBox\Qt5CoreVBox.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5CoreVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ff9da7b0000 LB 0x005f7000 C:\Program Files\Oracle\VirtualBox\Qt5GuiVBox.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5GuiVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 0000000073db0000 LB 0x00561000 C:\Program Files\Oracle\VirtualBox\Qt5WidgetsVBox.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5WidgetsVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3e8a0000 LB 0x000cd000 C:\WINDOWS\System32\OLEAUT32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\oleaut32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ff9ba430000 LB 0x02317000 C:\Program Files\Oracle\VirtualBox\UICommon.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\UICommon.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 0000000075ea0000 LB 0x00054000 C:\Program Files\Oracle\VirtualBox\Qt5OpenGLVBox.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\Qt5OpenGLVBox.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa2b140000 LB 0x00027000 C:\WINDOWS\SYSTEM32\WINMM.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\winmm.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ff9de070000 LB 0x001c8000 C:\Program Files\Oracle\VirtualBox\VirtualBoxVM.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VirtualBoxVM.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedIsApiSetDll: ApiSetQueryApiSetPresence(api-ms-win-core-synch-l1-2-0) -> 0x0, fPresent=1
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=api-ms-win-core-synch-l1-2-0 (rcNtResolve=0x0) *pfFlags=0x0 pwszSearchPath=0000000000000801:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3ccc0000 'api-ms-win-core-synch-l1-2-0'
3c7c.2ad0: supR3HardenedIsApiSetDll: ApiSetQueryApiSetPresence(api-ms-win-core-fibers-l1-1-1) -> 0x0, fPresent=1
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=api-ms-win-core-fibers-l1-1-1 (rcNtResolve=0x0) *pfFlags=0x0 pwszSearchPath=0000000000000801:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3ccc0000 'api-ms-win-core-fibers-l1-1-1'
3c7c.2ad0: supR3HardenedIsApiSetDll: ApiSetQueryApiSetPresence(api-ms-win-core-localization-l1-2-1) -> 0x0, fPresent=1
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=api-ms-win-core-localization-l1-2-1 (rcNtResolve=0x0) *pfFlags=0x0 pwszSearchPath=0000000000000801:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3ccc0000 'api-ms-win-core-localization-l1-2-1'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\kernel32.dll (Input=kernel32, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000801:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3ee00000 'C:\WINDOWS\System32\kernel32.dll'
3c7c.2ad0: supR3HardenedIsApiSetDll: ApiSetQueryApiSetPresence(api-ms-win-core-string-l1-1-0) -> 0x0, fPresent=1
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=api-ms-win-core-string-l1-1-0 (rcNtResolve=0x0) *pfFlags=0x0 pwszSearchPath=0000000000000801:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3ccc0000 'api-ms-win-core-string-l1-1-0'
3c7c.2ad0: supR3HardenedIsApiSetDll: ApiSetQueryApiSetPresence(api-ms-win-core-datetime-l1-1-1) -> 0x0, fPresent=1
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=api-ms-win-core-datetime-l1-1-1 (rcNtResolve=0x0) *pfFlags=0x0 pwszSearchPath=0000000000000801:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3ccc0000 'api-ms-win-core-datetime-l1-1-1'
3c7c.2ad0: supR3HardenedIsApiSetDll: ApiSetQueryApiSetPresence(api-ms-win-core-localization-obsolete-l1-2-0) -> 0x0, fPresent=1
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=api-ms-win-core-localization-obsolete-l1-2-0 (rcNtResolve=0x0) *pfFlags=0x0 pwszSearchPath=0000000000000801:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3ccc0000 'api-ms-win-core-localization-obsolete-l1-2-0'
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #25 'win32u.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\imm32.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\imm32.dll
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\system32\IMM32.DLL (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000009:<flags> [calling]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3e6d0000 LB 0x00030000 C:\WINDOWS\System32\IMM32.DLL [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\imm32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3e6d0000 'C:\WINDOWS\system32\IMM32.DLL'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: error opening 'C:\WINDOWS\System32\edgegdi.dll': 0 (NtPath=\??\C:\WINDOWS\System32\edgegdi.dll; Input=edgegdi.dll; rcNtGetDll=0xc0000135
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0xc0000034 'C:\WINDOWS\System32\edgegdi.dll'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\Program Files\Oracle\VirtualBox\VBoxRT.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ff9db4f0000 'C:\Program Files\Oracle\VirtualBox\VBoxRT.dll'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\ADVAPI32.DLL (Input=ADVAPI32.DLL, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3e620000 'C:\WINDOWS\System32\ADVAPI32.DLL'
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\cryptbase.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\cryptbase.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3c480000 LB 0x0000c000 C:\WINDOWS\SYSTEM32\CRYPTBASE.DLL [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\cryptbase.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3d210000 LB 0x00083000 C:\WINDOWS\System32\bcryptPrimitives.dll [fFlags=0x0]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\bcryptprimitives.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\bcryptprimitives.dll
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ff9de070000 'C:\Program Files\Oracle\VirtualBox\VirtualBoxVM.dll'
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #31 'combase.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #32 'msvcp_win.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #34 'wldp.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\windows.storage.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\windows.storage.dll
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\wldp.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\wldp.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3c570000 LB 0x0002c000 C:\WINDOWS\SYSTEM32\Wldp.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\wldp.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3a830000 LB 0x00791000 C:\WINDOWS\SYSTEM32\windows.storage.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\windows.storage.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3f150000 LB 0x000ae000 C:\WINDOWS\System32\SHCORE.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #42 'combase.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\SHCore.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\SHCore.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3dd50000 LB 0x00055000 C:\WINDOWS\System32\shlwapi.dll [fFlags=0x0]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\shlwapi.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\shlwapi.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'wldp.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'wldp.dll' -> '\Device\HarddiskVolume5\Windows\System32\wldp.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\wldp.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\kernel32.dll (Input=kernel32.dll, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\profapi.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\profapi.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3ca40000 LB 0x0001f000 C:\WINDOWS\SYSTEM32\profapi.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\profapi.dll [lacks WinVerifyTrust]
3c7c.2ad0: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\platforms\qwindows.dll: Signature #1/2: info status: 24202
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'ole32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'imm32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #4 'winmm.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #5 'oleaut32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #6 'shell32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #8 'qt5guivbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #9 'qt5corevbox.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #10 'msvcr100.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 24202 (\Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\platforms\qwindows.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\platforms\qwindows.dll
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\winmm.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'imm32.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'imm32.dll' -> '\Device\HarddiskVolume5\Windows\System32\imm32.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\imm32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\Program Files\Oracle\VirtualBox\platforms\qwindows.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\platforms\qwindows.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ff9f5b00000 LB 0x0012e000 C:\Program Files\Oracle\VirtualBox\platforms\qwindows.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 24202 (0x5e8a)) on \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\platforms\qwindows.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ff9f5b00000 'C:\Program Files\Oracle\VirtualBox\platforms\qwindows.dll'
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #7 'msvcrt.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #8 'rpcrt4.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\kernel.appcore.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\kernel.appcore.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3b3c0000 LB 0x00012000 C:\WINDOWS\SYSTEM32\kernel.appcore.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\kernel.appcore.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #34 'user32.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 22900 (\Device\HarddiskVolume5\Windows\System32\uxtheme.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\uxtheme.dll
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\system32\uxtheme.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000009:<flags> [calling]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\uxtheme.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3a140000 LB 0x0009e000 C:\WINDOWS\system32\uxtheme.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\uxtheme.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3a140000 'C:\WINDOWS\system32\uxtheme.dll'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3ebe0000 'C:\WINDOWS\system32\user32.dll'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\system32\shell32.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3d540000 'C:\WINDOWS\system32\shell32.dll'
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\SHCore.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\system32\SHCore.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3f150000 'C:\WINDOWS\system32\SHCore.dll'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: error opening 'C:\WINDOWS\system32\wintab32.dll': 0 (NtPath=\??\C:\WINDOWS\system32\wintab32.dll; Input=C:\WINDOWS\system32\wintab32.dll; rcNtGetDll=0x0
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0xc0000034 'C:\WINDOWS\system32\wintab32.dll'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\system32\winmm.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa2b140000 'C:\WINDOWS\system32\winmm.dll'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\system32\uxtheme.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3f110000 'C:\WINDOWS\system32\gdi32.dll'
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3eff0000 LB 0x00115000 C:\WINDOWS\System32\MSCTF.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #10 'oleaut32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #36 'user32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #38 'imm32.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\msctf.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\msctf.dll
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\rpcrt4.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3eec0000 'C:\WINDOWS\System32\rpcrt4.dll'
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3d430000 LB 0x000a9000 C:\WINDOWS\System32\clbcatq.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #30 'rpcrt4.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\clbcatq.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\clbcatq.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #26 'd3d11.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #27 'dcomp.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 22900 (\Device\HarddiskVolume5\Windows\System32\DataExchange.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\DataExchange.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'dcomp.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'dcomp.dll' -> '\Device\HarddiskVolume5\Windows\System32\dcomp.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'msvcp_win.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\dcomp.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\dcomp.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'd3d11.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'd3d11.dll' -> '\Device\HarddiskVolume5\Windows\System32\d3d11.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #26 'dxgi.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #28 'win32u.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\d3d11.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\d3d11.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'dxgi.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'dxgi.dll' -> '\Device\HarddiskVolume5\Windows\System32\dxgi.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #2 'win32u.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\dxgi.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\dxgi.dll
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\system32\dataexchange.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000002009:<flags> [calling]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\DataExchange.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\d3d11.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\dcomp.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\dxgi.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3b430000 LB 0x000f4000 C:\WINDOWS\system32\dxgi.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\dxgi.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa38d60000 LB 0x00264000 C:\WINDOWS\system32\d3d11.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\d3d11.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa39130000 LB 0x001e6000 C:\WINDOWS\system32\dcomp.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\dcomp.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa13140000 LB 0x0003e000 C:\WINDOWS\system32\dataexchange.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\DataExchange.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3f110000 'C:\WINDOWS\System32\gdi32.dll'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa13140000 'C:\WINDOWS\system32\dataexchange.dll'
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #43 'combase.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #45 'msvcp_win.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\twinapi.appcore.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\twinapi.appcore.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa36970000 LB 0x00201000 C:\WINDOWS\system32\twinapi.appcore.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\twinapi.appcore.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'msvcrt.dll'.
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\winmmbase.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\winmmbase.dll
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa16480000 LB 0x00026000 C:\WINDOWS\SYSTEM32\winmmbase.dll [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\winmmbase.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #15 'oleaut32.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #17 'rpcrt4.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #20 'coreuicomponents.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #21 'coremessaging.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\TextInputFramework.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\TextInputFramework.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #35 'coremessaging.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #40 'rpcrt4.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #48 'shcore.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\CoreUIComponents.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\CoreUIComponents.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #20 'ws2_32.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\CoreMessaging.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\CoreMessaging.dll
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\ntmarta.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\ntmarta.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #3 'combase.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #24 'rpcrt4.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #32 'bcryptprimitives.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\WinTypes.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\WinTypes.dll
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa3b830000 LB 0x00033000 C:\WINDOWS\SYSTEM32\ntmarta.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\ntmarta.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa39a00000 LB 0x000f2000 C:\WINDOWS\System32\CoreMessaging.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\CoreMessaging.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa38fd0000 LB 0x00154000 C:\WINDOWS\SYSTEM32\wintypes.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\WinTypes.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa39320000 LB 0x0035e000 C:\WINDOWS\System32\CoreUIComponents.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\CoreUIComponents.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa30170000 LB 0x000f9000 C:\WINDOWS\SYSTEM32\textinputframework.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\TextInputFramework.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\msctf.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #0 'msvcp_win.dll'.
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #16 'rpcrt4.dll'.
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #28 'devobj.dll'.
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'devobj.dll'...
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\MMDevAPI.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\MMDevAPI.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'devobj.dll' -> '\Device\HarddiskVolume5\Windows\System32\devobj.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #18 'cfgmgr32.dll'.
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\devobj.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\devobj.dll
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'bcryptprimitives.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'bcryptprimitives.dll' -> '\Device\HarddiskVolume5\Windows\System32\bcryptprimitives.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\bcryptprimitives.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #18 'cfgmgr32.dll'.
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\devobj.dll)
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa3d160000 LB 0x0004e000 C:\WINDOWS\System32\cfgmgr32.dll [fFlags=0x0]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'shcore.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'shcore.dll' -> '\Device\HarddiskVolume5\Windows\System32\shcore.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\SHCore.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'rpcrt4.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'rpcrt4.dll' -> '\Device\HarddiskVolume5\Windows\System32\rpcrt4.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\rpcrt4.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'coremessaging.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'coremessaging.dll' -> '\Device\HarddiskVolume5\Windows\System32\coremessaging.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\CoreMessaging.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'coreuicomponents.dll'...
3c7c.2ad0: supR3HardenedWinVerifyCacheProcessImportTodos: 'coreuicomponents.dll' -> '\Device\HarddiskVolume5\Windows\System32\coreuicomponents.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\CoreUIComponents.dll [lacks WinVerifyTrust]
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\cfgmgr32.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\cfgmgr32.dll
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa3c8c0000 LB 0x0002c000 C:\WINDOWS\SYSTEM32\DEVOBJ.dll [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\devobj.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa2e710000 LB 0x00085000 C:\WINDOWS\SYSTEM32\MMDevAPI.DLL [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\MMDevAPI.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'mmdevapi.dll'.
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #2 'ksuser.dll'.
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #30 'avrt.dll'.
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 22900 (\Device\HarddiskVolume5\Windows\System32\wdmaud.drv)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\wdmaud.drv
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'avrt.dll'...
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'avrt.dll' -> '\Device\HarddiskVolume5\Windows\System32\avrt.dll' [rcNtRedir=0xc0150008]
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\avrt.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\avrt.dll
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'ksuser.dll'...
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'ksuser.dll' -> '\Device\HarddiskVolume5\Windows\System32\ksuser.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\MSCTF.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000009:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3eff0000 'C:\WINDOWS\System32\MSCTF.dll'
3c7c.2ad0: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #6 'rpcrt4.dll'.
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\ksuser.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\ksuser.dll
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'mmdevapi.dll'...
3c7c.2ad0: supHardenedWinVerifyImageByHandle: -> 22900 (\Device\HarddiskVolume5\Windows\System32\oleacc.dll)
3c7c.2ad0: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\oleacc.dll
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'mmdevapi.dll' -> '\Device\HarddiskVolume5\Windows\System32\mmdevapi.dll' [rcNtRedir=0xc0150008]
3c7c.189c: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\MMDevAPI.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'msvcrt.dll'...
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'msvcrt.dll' -> '\Device\HarddiskVolume5\Windows\System32\msvcrt.dll' [rcNtRedir=0xc0150008]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\system32\Oleacc.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000009:<flags> [calling]
3c7c.189c: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\msvcrt.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'cfgmgr32.dll'...
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'cfgmgr32.dll' -> '\Device\HarddiskVolume5\Windows\System32\cfgmgr32.dll' [rcNtRedir=0xc0150008]
3c7c.189c: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\cfgmgr32.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\oleacc.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedDllNotificationCallback: load 00007ffa2bcc0000 LB 0x00066000 C:\WINDOWS\system32\Oleacc.dll [fFlags=0x0]
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\wdmaud.drv (Input=wdmaud.drv, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000001001:<flags> [calling]
3c7c.2ad0: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\oleacc.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa2bcc0000 'C:\WINDOWS\system32\Oleacc.dll'
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\OLEAUT32.DLL (Input=OLEAUT32.DLL, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3e8a0000 'C:\WINDOWS\System32\OLEAUT32.DLL'
3c7c.189c: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\wdmaud.drv [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\system32\oleacc.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa2bcc0000 'C:\WINDOWS\system32\oleacc.dll'
3c7c.189c: supR3HardenedScreenImage/NtCreateSection: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\ksuser.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\Windows\System32\oleacc.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000002009:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa2bcc0000 'C:\Windows\System32\oleacc.dll'
3c7c.189c: supR3HardenedScreenImage/NtCreateSection: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\avrt.dll [lacks WinVerifyTrust]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: pName=C:\Windows\System32\oleaut32.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000002009:<flags> [calling]
3c7c.2ad0: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa3e8a0000 'C:\Windows\System32\oleaut32.dll'
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa35690000 LB 0x00009000 C:\WINDOWS\SYSTEM32\ksuser.dll [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\ksuser.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa37390000 LB 0x0000a000 C:\WINDOWS\SYSTEM32\AVRT.dll [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\avrt.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa2fcc0000 LB 0x00046000 C:\WINDOWS\System32\wdmaud.drv [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\wdmaud.drv [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa2fcc0000 'C:\WINDOWS\System32\wdmaud.drv'
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\MMDEVAPI.DLL (Input=MMDEVAPI.DLL, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa2e710000 'C:\WINDOWS\System32\MMDEVAPI.DLL'
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #5 'rpcrt4.dll'.
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #7 'oleaut32.dll'.
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #29 'mmdevapi.dll'.
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\AudioSes.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\AudioSes.dll
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'oleaut32.dll'...
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'oleaut32.dll' -> '\Device\HarddiskVolume5\Windows\System32\oleaut32.dll' [rcNtRedir=0xc0150008]
3c7c.189c: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\oleaut32.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'rpcrt4.dll'...
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'rpcrt4.dll' -> '\Device\HarddiskVolume5\Windows\System32\rpcrt4.dll' [rcNtRedir=0xc0150008]
3c7c.189c: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\rpcrt4.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'msvcp_win.dll'...
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'msvcp_win.dll' -> '\Device\HarddiskVolume5\Windows\System32\msvcp_win.dll' [rcNtRedir=0xc0150008]
3c7c.189c: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\msvcp_win.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\AUDIOSES.DLL (Input=AUDIOSES.DLL, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000000001:<flags> [calling]
3c7c.189c: supR3HardenedScreenImage/NtCreateSection: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\AudioSes.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #12 'rpcrt4.dll'.
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\powrprof.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\powrprof.dll
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa3c4c0000 LB 0x0004b000 C:\WINDOWS\SYSTEM32\powrprof.dll [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\powrprof.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa2e7a0000 LB 0x00181000 C:\WINDOWS\System32\AUDIOSES.DLL [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\AudioSes.dll [lacks WinVerifyTrust]
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\umpdc.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\umpdc.dll
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa3c330000 LB 0x00012000 C:\WINDOWS\SYSTEM32\UMPDC.dll [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\umpdc.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa2e7a0000 'C:\WINDOWS\System32\AUDIOSES.DLL'
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #12 'mmdevapi.dll'.
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #13 'msacm32.dll'.
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 22900 (\Device\HarddiskVolume5\Windows\System32\msacm32.drv)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\msacm32.drv
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'msacm32.dll'...
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'msacm32.dll' -> '\Device\HarddiskVolume5\Windows\System32\msacm32.dll' [rcNtRedir=0xc0150008]
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 0 (\Device\HarddiskVolume5\Windows\System32\msacm32.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\msacm32.dll
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\msacm32.drv (Input=msacm32.drv, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000001001:<flags> [calling]
3c7c.189c: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\msacm32.drv [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedScreenImage/NtCreateSection: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\msacm32.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa353d0000 LB 0x0001e000 C:\WINDOWS\SYSTEM32\MSACM32.dll [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\msacm32.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa355e0000 LB 0x0000d000 C:\WINDOWS\System32\msacm32.drv [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\msacm32.drv [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa355e0000 'C:\WINDOWS\System32\msacm32.drv'
3c7c.189c: supR3HardenedWinVerifyCacheScheduleImports: Import todo: #1 'winmmbase.dll'.
3c7c.189c: supHardenedWinVerifyImageByHandle: -> 22900 (\Device\HarddiskVolume5\Windows\System32\midimap.dll)
3c7c.189c: supR3HardenedWinVerifyCacheInsert: \Device\HarddiskVolume5\Windows\System32\midimap.dll
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: Processing 'winmmbase.dll'...
3c7c.189c: supR3HardenedWinVerifyCacheProcessImportTodos: 'winmmbase.dll' -> '\Device\HarddiskVolume5\Windows\System32\winmmbase.dll' [rcNtRedir=0xc0150008]
3c7c.189c: supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\winmmbase.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\midimap.dll (Input=midimap.dll, rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000001001:<flags> [calling]
3c7c.189c: supR3HardenedScreenImage/NtCreateSection: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\midimap.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedDllNotificationCallback: load 00007ffa352d0000 LB 0x0000b000 C:\WINDOWS\System32\midimap.dll [fFlags=0x0]
3c7c.189c: supR3HardenedScreenImage/LdrLoadDll: cache hit (Unknown Status 22900 (0x5974)) on \Device\HarddiskVolume5\Windows\System32\midimap.dll [lacks WinVerifyTrust]
3c7c.189c: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa352d0000 'C:\WINDOWS\System32\midimap.dll'
3c7c.3b24: supR3HardenedScreenImage/LdrLoadDll: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume5\Windows\System32\MMDevAPI.dll [lacks WinVerifyTrust]
3c7c.3b24: supR3HardenedMonitor_LdrLoadDll: pName=C:\WINDOWS\System32\MMDevApi.dll (rcNtResolve=0xc0150008) *pfFlags=0x0 pwszSearchPath=0000000000002009:<flags> [calling]
3c7c.3b24: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ffa2e710000 'C:\WINDOWS\System32\MMDevApi.dll'
1de8.1a7c: supR3HardNtChildWaitFor[1]: Quitting: ExitCode=0x1 (rcNtWait=0x0, rcNt1=0x0, rcNt2=0x103, rcNt3=0x103, 24643 ms, the end);
Código de Resultado:
E_FAIL (0x80004005)
Componente:
MachineWrap
Interface:
IMachine {85632c68-b5bb-4316-a900-5eb28d3413df}
- 1 reply
- 3,544 views
ares-launch ERR! CLI: luna-send command failed <Failed to launch webapp in WAM>
By Syed Jalal,
- ares-launch
- emulator
- (and 1 more)
- 1 reply
- 5,098 views
- 0 replies
- 10,491 views
- 3 answers
- 15,045 views
Webosdev
I have downloaded full package and installed the emulator 6.0. It shows only black blank screen and few red lines on the top.
