Subtitles disappeared after webs update 5.10.25
After updating my TV recently to webos version 05.10.25, subtitles disappeared from multiple programs.
i checked for updates, but nothing is available
my TV is webOS TV SM8100PVA
    • By mean2
    • By OliverRC
    • By Ajothen
    • By atcronin
