Youtube app incorrect Geo data- resolved
Go to solution Solved by Miroslav Tuhársky,
  • Solution
Hello, I have LG OLED CX and recently the Youtube app has incorrect geographic data- CH. I am from Slovakia, the TV has never been to Switzerland. Nor physically, nor virtually (VPN). I am getting CH ads, which I dont mind so much, but I am afraid of possible in app geo restrictions.
I already tried everything, even resetting the TV to default.  No other TV app is affected.
Anybody please advise.
      for AI Data Centers
    • By Lee Magee
    • By Will M
    • By David Joseph
    • By Владимир Морозов
