Moving recording to a different USB Disk
Hi I have a LG Smart TV (OLED55B16LA) and started using the recording feature.
I would like to replace the USB HDD with a bigger one, so I have copied all the files from the old one to the new one.
But when I put the new one in the TV it does not recognise it as a recording, it lets me browse the content. but of course being scrambled it is pointless.
Is it possible to move all the recordings to a different disk and use it in the same TV?
Cheers
    • By Sqwazy
    • By Hoghton Jim
      Many thanks.
    • By StefanosBand
    • By Kev999
      I can only get the Reminder facility to work on live TV in the lower channels like 1, 2, 3 etc, but rejects attempts to use with the HD channels at 101, 102 etc.   Is this normal?
    • By Nooneuno
      Our tv always needs to have the recording volume reset... the problem seems to be that the formatted disk has a small boot partition, about 150 mb, plus a 4 GB "main" volume, and the recording app "sees' the boot partition, and won't "hold" the setting for the main volume...
