Tv switches on and regular program schedule reminders when there are none?
By JasonB
By Peter_T
By Will M
By wallyricks
By Nick Payne
Chris Jones
My TV is driving me nuts!
I keep getting reminders for programs starting for programs I don’t watch or have never watched and 2. The tv even switches on for scheduled programs that I haven’t set.. actually I have only ever set one program reminder and that has now been deleted.
I can’t see any programs in the reminder page or anywhere in the tv programmer?
Short of resetting the tv I don’t know what else to try? And I don’t really want to do that until I know how the tv ended up like this? Plus I don’t want to have to reload and sign in to all my apps 😬
