LGOLED65C8 - loss of satellite signal
By OhmorrowSouthWales
By Michael Hirons
Can anyone advise me whether this tuner is "generic" or freesat? and i would like advise on using it with a Sky+HD satellite dish.. any advice/help appreciated as im cancelling sky contract soon Michael
By Tony Levy
I live in Spain hence the two systems. When I press the home button on the remote the list is at the bottom and displayed are LG Content Store HDMI3, LiveTV Freesat etc but no button with the aerial option, so the only way I can switch is to go into the main settings menu select Programme Tuning and switch the programme mode from Satellite to Antenna.
By leader6234
Hey guys !!!
Thanks in advance !!!
By andreluigo
I used to extend my screen from PC/Notebook to my TV but i stayed a long period without do it.
It happens that since a few days ago i am needing it and for my surprise is not working anymore. Tried other cables, updated the drivers and O.S. but nothing worked. So i decided test at the room's TV (LG as well) and worked perfetcly.
I looked for all internet and youtube for similar issues and a solution but couldn't find it, until i receive my weekly mail from this forum and remembered it.
I am suspicious that was one of the several updates since i extended for the last time that made this!
So, does anybody could help me, please?
Thanks in advance!
oled lg65c8pla
As in the topic, I'm watching TV and suddenly the signal is lost and the wallpaper with the information "no signal" appears, I turn off the TV and turn on the TV again and the image appears, I have a second TV on this satellite antenna and nothing like that happens there, so it's not antenna fault. What could be wrong.
