Application can not installed
When I updated an application from lg content store .. I get the sign that this application  has not been  installed try again ??
what can I do to solve this
thanks
    • By Junaid Ahmed
    • By Ganesh R
      Hi LG Team,
      Regards,
      Ganesh R
    • By Nishant singh
      Hi Team
    • Solution For That Pollution
    • By AVTech
      I have been in hi end AV technology for years and I have purchased a ThinQ "smart" TV. After finally finding a way to stop the ridiculous loud static start up now I want to find a way to have the TV start at an installed app (Google TV etc.) instead of the unused antenna or HDMI input. It seem this would be the default if not just an option on a smart TV when actually using installed apps. Have I been missing something or is this some bizarre epic fail?
