LG OLED48C14LB and Alexa
Hi all, First time poster!
I have the above TV (UK based) with an Alexa Show in my home. The TV has Alexa on it which is fine and the TV has been discovered by the Alex Show 5 and also in my iPhone App.
I can turn the TV on with the Alexa Show... but like hell will it turn off.
I have both LG skills installed (basic and complete) and the TV is wired into to the home network.
It will only turn on if I call it by my name. If I call it by any other name (Office TV, LG TV) it will not turn on.
So I call the TV by my name and it turns on, great... create a routine to add in my Xbox Series X and all done.
It will not turn off. At all. It keeps saying "Sorry TV doesn't Support that or Check network connection and try again".
I have used "Alexa, turn off office TV" and "Alexa..... tell LG to turn off office television" plus a few others but it will not turn it off.
This is the kicker..... Apple Homekit on my iPhone will turn it off and on no issues at all.
What am I missing with the Alexa Show 5 that it won't turn off??
I am trying to see if I can link the Alexa routine to an Apple Homekit to turn it off but seems a lit way out there for something that should be simple.
Any and all help is greatly appreciated.
    • By Trevin
    • By Citron2010
      Hi,  I have an LG 43UN71006LB with OS v4.50.53 (latest)
      I thought I'd test this on my TV and it works very well.  I've even set "routines" on Alexa so that saying "Alexa, BBC 1" is a shortcut for "Alex, change the channel on LGTV to 101" etc.
      Also tried:
      "Alexa, enable Sound Share on LGTV"  - "that command doesn't work on device LGTV"
      Anyone have any ideas?
    • By Sandy8100
      Alexa installed correctly on    32lq63 TV.
      remote that came with to does not appear to have a microphone. How do I control Alexa?
      Simple instructions for a simple person please !
    • By NThakare
      Until last few months, alexa was working with all the commands, now open any app like Youtube, Netflix, etc not working
      Play or Pause any app videos not working, don't know what's going on with lgtv, i bought around 1000 dollar tv and this important feature isn't working
    • By NThakare
      Hi all,
      If u all can check, alexa on my lg c2 oled 55 inch has stopped working sometimes it gives error like its unable to connect to server and now when i give commands to play or pause any music or video, it says it can not do it.
      I have reset it multiple times it does not work.
      Many users on alexa app skills for lg tv webos are also talking about the same, that means its not limited to me only
