How can I disable wifi-direc
Annoying random people (I live close to a hotel) keep trying to connect to my TV (probably by mistake) and a message shows up in the middle of my screen everytime!
How can I stop this?
How to turn off WI fi on TV.
- Settings
- Connections
- Network connection settings
- WiFi connection
- Toggle WiFi on/off
Make sure wired setting is turned  off under network connection settings. You may have to enter your ip settings for wired connection.
Hope this helps.
    • By mycop
      Greetings.
    • By StanJ
      I've seen an older thread on this topic but it doesn't look like anyone found a solution to disabling the screen saver, so I'll try a new one.
      On virtually all my LG TV's (I have three OLED's and two LCD), the screen saver interferes with my music app (like Plex, Spotify or Amazon Music). I mainly use Plex for playback of my music which is stored on a central server (NAS) and from the app loaded on a Fire TV stick or cube. After about 20-30 minutes, the album art and other related music information (lyrics, song title, duration, etc) all goes black. If I run Plex (or Spotify) directly on the LG TV via the LG Content store app, the screen saver with fireworks always comes on in about 2 minutes.
      I've tried all the different methods to disable the screen saver function including turning off the Timers, Auto Power Off,  HDD Storage, etc. I also tried opening the hidden menus by pressing the mute button 5 times but that menu didn't have anything relevant.
      Interesting is that the screen saver doesn't come on when using Spotify on a Fire TV stick or if I playback music through a USB device. But i don't use those methods often, mainly Plex to access my music server where I have about 500 CD's stored in ALAC format.
      Has anyone found a way to disable the screen saver function? I know the logic for having it (to prevent OLED burn in) but I'm not leaving the same image on for more than the song duration (about 3-5 minutes).  It's annoying to check the screen for the a music title or see who is on only to find a black screen looking back. Thanks for any help.
    • By duckie133
      VERY ANNOYING!!!!!!!!!!
    • By curious george
      Hi, I'd like to disable the bluetooth on my G2 and was wondering if this was possible without having to disconnect the bluetooth module in the back?
    • By Benjamin De Graaf
      As in title.
      Everytime I watch something on Plex I get constant Dolby vision pop ups, sometimes random and sometimes staying for multiple minutes.
      there isn’t anything wrong with the playback, it’s just the constant pop ups that are very annoying and frustrating that I can’t disable them.
      Other manufacturers have the option to disable it, so I can’t imagine why webos shouldn’t have it.
      thanks in advance, have a nice holiday!
