LG Smart TV model UHD LED 55UF850T Not able to connect Alexa Show 8
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
By Annie Yazbeck
I can't find the Spotify app on the LG Content Store. When I search it, there is no result. Anyone can help me to get Spotify on LG Smart TV? I tried to use DRmare Software to download Spotify songs to USB flash drive and play them on my LG Smart TV offline for free. But I prefer to use it via the Spotify app directly.
Sameer Zunjar
Hi Team,
I purchased Lg smart tv UHD LED 55UF850T in December 2015.
Yesterday I bought alexa show 8 device, but I am facing issue to connect Alexa device to my Lg smart tv UHD LED 55UF850T.
Can you please help me how can I connect?
Hope so it will be positive response.
Please do it ASAP.
