Update 06.00.25 error
By mean2
By OliverRC
By Ajothen
By Roy Brown
By Batman
HvH
After updating my LG 60SJ850V to version 06.00.25 software everything went wrong...
Connected via ethernet cable and youtube has buffering issues. Get stuck for few seconds and then sped thtough for few. Has good fibre connection and never had this issue.
Also when watching from external hard drive, the video's get stuck and giving issues where there never were any problems.
Can't connect TV to wifi anymore.
Message toggles between LAN cable disconnected followed by LAN ethernet connected the whole time.
Smart remote has connection issues.
This is extremely annoying. How can I get these issues fixed? Tried all the fixes that I could find for previous software update problems, but nothing works.
