Epk file for LG50LB6500.
By MinoDc
Hi to all.
What do you think
By Jonatan de la Torre Gómez
By Lorenz
By odesanmi kolade
I have been trying to downloading Aptoide TV on my LG smart Tv but keep showing File downloading not supported.. My goal is how I can get zoom conference app running on my Smart Tv. Please help!!!
By Darshan Giri
I was unable to install the remote control app(on TV) after bundling with Sandstorm webdriver code. Getting below error. ares-install ERR! [com.webos.appInstallService failure]: luna-send command failed <update manifest file failed>
Nipuna Prabath
My tv has software version - 05.05.70, model - WEBOS1, webos tv version - 1.4.0-2532
Please help me to do the update . I need to find correct epk file. Automatic updates doesn't work
