JogStats
Way back in the day when you went for a run, you just ran. Then came the Walkman, which brought music. Pedometers gave us our first logging capabilities, but that was fairly rudimentary. In recent years you could go with a fairly rudimentary and exceedingly expensive GPS-based tracker, but the user experience of those almost always left something to be desired. Fast forward to today, a time where every smartphone platform has multiple inexpensive apps that not only can track your run live, they log it with more information and analysis at your fingertips than we've ever had before.
One such app for webOS is
, a $3.49 creation by Rusty Apps. JogStats brings a level of polish and webOS-ness that some other run tracker apps lack, and has the added bonus of being mostly functional. Unlike some other run trackers, JogStats does not have a cloud backend, which while this means you can't automatically backup your runs and look at them from other devices, it also means (1) you don't have to deal with needed a data connection (GPS tracking is going to drain your battery fast enough) and (2) you don't have to futz around with online systems that change while the webOS app is left abandoned. The question is how willing you are to live without web access to your logs.
a2t.imgOjoLazm7FQg
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
        Q10 in 90 minutes
