WebOS loses connection to QNAP NAS DLNA Media Server
By crct
By Roy Brown
By Khelben Arunsun
By magicschooldropout9
By AmuLulu
- 1 answer
- 10,565 views
- 1 answer
- 27,648 views
- 2 answers
- 15,293 views
Fred Wan
The problem that my QNAP NAS Mediaserver disappears from the WebOS Home screen and from the Home dashboard happens irregularly and unpredictably almost daily. The only way to get it back is to reset WebOS to its initial (factory) settings. After I do that, it always reappears on the Home scree/Home dashboard. I have no idea why this happens, it even happens after I watch an hour of movie content from the NAS and then want to browse through the files on the NAS: it suddenly is not accessible anymore. I tried to tweak (a lot of) the NAS settings but nothing helps.
My NAS has a fixed IP in my home LAN. Is it possible to connect to it with the IP address?
Any other suggestions how to remedy this tedious problem are welcome!
In the file attached is a photo of the Home dashboard with the Mediaserver present.
