PreCentral: Mobile Nations fitness month: Week 3! [TouchPad + Xbox Kinect giveaway]
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
The LG Styler Steam Clothing Care System has become an essential appliance in many Taiwanese households, addressing health concerns as well as enhancing clothing appearance. On October 9, LG Taiwan hosted a press conference to mark the official launch of the ALL NEW Styler.
For the first time, LG Taiwan collaborated with Taipei Fashion Week, creating a massive Styler-shaped pop-up store in the Xinyi Xiangti Avenue Plaza. The exhibition space was designed to make guests and media feel as though they were stepping inside the Styler. Attendees could try out the LG ALL NEW Styler and get a firsthand look at features typically hidden when the machine is in operation.
LG Taiwan also partnered with acclaimed independent design brand DOUCHANGLEE, co-founded by renowned fashion designers Dou Teng Hwang and Changlee Yugin. The designers attended the event to endorse the LG Styler, showcasing how the product enables consumers to express their style without the limitations of traditional clothing care.
The pop-up store featured demonstrations of the LG ALL NEW Styler’s powerful new functions, including the upgraded Dual Steam Clothing Care technology and the Smart Shaking Hanger. Guests experienced AI-powered care recommendations, a built-in high-pressure steam iron and a foldable pants press. The event provided plenty of valuable material for the media.
Designers Dou Teng Hwang and Changlee Yugin took the stage to share their experience working with LG Taiwan, praising the ALL NEW Styler’s steam care capabilities and built-in steam ironing system. They also discussed how the installation of the LG Styler at DOUCHANGLEE’s Zhongshan concept store introduced a new perspective on garment care to consumers.
LG Styler’s latest showcase highlighted the brand’s innovative fusion of technology and fashion-forward design. Through an impressive life-sized display, the premium garment care solution demonstrated how advanced technology can transform daily clothing care routines, reinforcing LG’s position as a leader in sophisticated home appliance solutions that resonate with style-conscious consumers.
Contributed by LG Taiwan
By pivotCE
Tools for the Job
– Needle nose pliers/tweezers
– Flush cuts
– Painter’s and kapton tape
Trim the USB C Board
Tape the USB C Board
Where To Get Power and Data
Put the Pieces Together
Congrats, You Now Have USB C
#webOS4ever
LG TV Owners Worldwide Gain Access to Exciting Offers, Including Discounts
and Free Trials from Global and Regional webOS Content Partners
SEOUL, Aug. 30, 2024 — LG Electronics (LG) is announcing the LG Streaming Week campaign in 44 countries, starting from September 9 and running through October 13,1 to celebrate a decade since the initial launch of webOS on the company’s LCD and OLED TVs. For owners of LG TVs above UHD released from 2018 onward (running webOS 4.0 and above), as well as StanbyME and StanbyME Go users, LG Streaming Week presents a variety of free and discounted subscriptions from service partners through its dedicated app, accessible from the Home Screen, Content Store or Apps.
Each promotional week will feature a different global and local partner line-up, with each partner limited offer accessible and redeemable solely on a weekly basis, from the LG Streaming Week app.2
LG Streaming Week boasts a range of enticing offers from content partners, such as free subscriptions of up to three months and up to 90 percent in discounts. Whether a fan of movies, sport, gaming, anime or cult classics, LG Streaming Week caters to a multitude of interests and preferences for a more captivating viewing experience.
Apple TV+3 is offering a three-month free trial, allowing LG TV owners to enjoy the latest premium Apple Originals, including the gripping psychological thriller Disclaimer, starring Academy Award-winners Cate Blanchett and Kevin Kline and created and directed by five-time Academy Award-winner Alfonso Cuarón. Plus, new seasons of the Emmy Award-nominated and BAFTA-Award winning drama Slow Horses; enthralling post-apocalyptic series Silo; and the sweeping and deeply moving drama Pachinko. Moreover, LG is providing customers with a three-month free trial of Apple Music.4 The award-winning Apple Music offers one of the largest catalogs of music in the world with over 100 million songs as well as over 30,000 expertly curated playlists, artist interviews, Apple Music Radio and so much more. Apple Music subscribers also have access to exciting features like Apple Music Sing and time-synced lyrics as well as lossless audio, and immersive Spatial Audio.
Movie enthusiasts will be delighted with the chance to explore films and series from multiple content providers across genres. New and returning Paramount+5 subscribers can get a 50 percent discount on an annual subscription of high-stakes dramas including Tulsa King, critically acclaimed projects like Fellow Travelers (Paramount+ with Showtime plan only in US), next-gen franchises that build on fan favorites like Knuckles, Star Trek: Strange New Worlds and Tales of the Teenage Mutant Ninja Turtles, along with an extensive library of even more hit series, blockbuster films, live sports and breaking news.
Mubi,6 a global streaming service, production company and film distributor dedicated to elevating great cinema all over the world, is offering LG TV owners during LG Streaming Week a chance to discover the best of cinema, in the comfort of their home, with 70 percent off for six months.
For sports fans, DAZN7 – the only place to watch NFL Game Pass (excluding US and China) – will be offering new customers 25 percent off a NFL Game Pass Season Pro subscription and a NFL Weekly Pro subscription for USD 0.99 or local currency equivalent. This will give LG TV owners the opportunity to watch every NFL game from every team, including the Playoffs and Super Bowl, live and on-demand. Plus get NFL RedZone, NFL Network, NFL Originals and much more, including a full suite of archive content.
What’s more, for those who prefer gaming or anime, LG Streaming Week has appealing offers for users of different tastes and interests. LG TV owners can embark on an anime adventure with 30 days free trial of Crunchyroll, where fans unlock the largest dedicated anime streaming library of over 25,000 hours of content and fresh series arriving every season. For an interactive experience, especially for LG TV owners, Blacknut8 Cloud Gaming offers a 30-minute free play session for any of their 500+ premium games and a special USD 1/first month subscription offer for new subscribers. For kids and families, Baby Shark World for Kids by The Pinkfong Company is granting 1 month of free access to its vast library of songs and stories that engage children in stimulating learning experiences.
To provide those who do not yet own an LG TV with the opportunity to take advantage of LG Streaming Week, the company is presenting several promotions on TV products across the global market. LG aims to expand its presence with enticing occasions for users to experience all that webOS has to offer on LG TVs.
The decade-long journey of webOS is marked by continuous innovation, demonstrating LG’s commitment to delivering content with a user-friendly interface for convenience and ease of use. Over the years, webOS has undergone a home screen overhaul that enhances usability and leverages the latest AI technology to effortlessly direct viewers to their preferred content. What’s more, the company’s recent webOS Re:New program enables LG AI TV owners to receive TV upgrades for a period of five years, enriching the user experience for a wider audience.
LG webOS highlights LG’s dedication to optimizing content consumption, with support from over 4,000 partners in 180 countries and millions of active users. Since its launch, webOS has evolved over 10 years to transform the home entertainment experience for easy-to-use viewing pleasure. Now available across LG TVs and lifestyle screens such as StanbyME and StanbyME Go, webOS has recorded significantly increased usage time, with consumers gradually shifting access from traditional TV to webOS, reflecting its widespread appeal to users around the world.
For further details about free and discounted content available during LG Streaming Week, visit the dedicated page on each regional LG.com site. Information on LG product promotions can also be found at
link hidden, please login to view. ###
1 LG Streaming Week 1 starts September 9 and redemptions for Week 1 offers close September 15. Week 2 starts September 16 and redemptions for Week 2 close September 22. Week 3 starts September 23 and redemptions for Week 3 offers close September 29. Week 4 starts September 30 and redemptions for Week 4 offers close October 6. Week 5 starts October 7 and redemptions for Week 5 offers close October 13. Select partner offers may start at a different date than the beginning of the week.
2 Partner offer can only be redeemed once via LG Streaming Week app.
3 Apple TV+ offer is available via LG Streaming app from September 9 and can also be accessed directly from Apple TV app in over 90 markets until November 17. Offer ends November 17. Offer available on 2018-2024 LG 4K, 8K Smart TV models, StanbyME and StanbyME Go models in the Apple TV app. Valid only for new and qualified returning subscribers to Apple TV+ in your region. Limit one offer per TV and Apple ID. Plan automatically renews at your region’s price per month until cancelled. Requires Apple ID with payment method on file. Payment will be billed to payment method on file and can be cancelled anytime at least a day before each renewal date in your service account settings. Terms and Apple Privacy Policy apply; see the applicable terms at Must be the minimum age required in your country and in the country that matches the store front on which you are redeeming the offer. Compatible products and services required. Cannot be combined with other offers providing access to the same service. Apple TV+ is a service mark of Apple Inc.
4 Apple Music offer is available via LG Streaming app from September 9 in 44 markets and can also be accessed directly from Apple Music app in 137 markets until April 30, 2025. Apple Spatial Audio with Dolby Atmos is available on LG OLED TV models launched from 2018 to 2024 and QNED TV models Q90T and above.
5 Paramount+ offer is available in 18 countries including US, Canada, United Kingdom, France, Italy, Austria, Switzerland, Republic of Ireland, Australia, Argentina, Brazil, Mexico, Colombia, Chile, Peru, Panama, Guatemala and Ecuador, where LG Streaming Week promotion is available. The total cost of the annual plan is billed upfront and after the first year, auto-renews at the then regular annual price of the annual price selected. Paramount+ U.S: Total cost of annual plan billed upfront. Auto-renews at then regular annual price (currently, plan start at USD 59.99/year + tax, as applicable).
Milan Design Week, the world’s largest and most well-known design and furniture fair, is a mecca for the aesthetically-inclined. At this year’s event, the biennially-held EuroCucina exhibition put the spotlight on the latest trends in kitchen appliances and furnishings, with many of the industry’s major players taking part. A regular at Milan Design Week, LG delivered a stunning showcase of premium built-in kitchen appliances at a booth designed by GamFratesi, the acclaimed architecture and design studio co-founded by Italian Enrico Fratesi and Denmark’s Stine Gam.
To highlight both the ultra-premium Signature Kitchen Suite and LG’s built-in appliance lineups, the diverse range of built-in products on display clearly reflected the company’s dedication to promoting an inspired culinary lifestyle centered around the joy of sharing and savoring quality food.
“One particularly memorable episode during our collaboration with LG was the differentiation strategy for Signature Kitchen Suite and LG built-in appliances,” said GamFratesi. “This differentiation strategy was well reflected in the booth design.”
The coming together of Signature Kitchen Suite’s True to Food philosophy – founded on the importance of preserving the original flavors of fresh ingredients – and GamFratesi’s design ethos revealed a new vision for kitchen design. LG’s emphasis on quality natural ingredients was echoed by the natural materials and design elements incorporated into the exhibition booth itself, which also reflected the impact of environment and culture on different cuisine traditions. GamFratesi’s subtle use of wood and stone accentuated the beauty of the natural world while simultaneously drawing attention to the connection we form with the planet when cooking and consuming real food.
“The key points to pay attention to are the design of each island and the materials used,” noted GamFratesi. “Each island represents an independent piece of furniture that reflects our design aesthetic.”
Within the booth’s Signature Kitchen Suite zones, GamFratesi complemented the built-in brand’s gorgeous kitchen appliances with natural materials and finishings. Each display kitchen represented a seamless harmony of appliances, cabinetry, counters and décor, highlighting the transformative power of design to create special sanctuaries that celebrate authentic cooking and nature’s beauty.
Evocative, entertaining, yet entirely elegant, the Signature Kitchen Suite wine cellar zone made a lasting impression on visitors to LG’s booth. Here, GamFratesi drew inspiration from the wine-maturation process to craft a calm, almost-meditative space with a ‘cave-like’ sense of depth and a rich, atmospheric mood.
Although the synergy between LG’s built-in appliances and GamFratesi’s kitchen designs is undeniable, the process of smoothly integrating the two for the Milan Design Week showcase was not without challenges. However, through the thoughtful and purposeful placement of appliances with distinct functionalities, and via the introduction of LG’s panel-ready concept, the two innovative companies achieved the ultimate union of form and function. The results, as one can see from the images, speak for themselves.
Through the unprecedented fusion of design, technology and space, the compelling collaboration between LG and GamFratesi presented a new kind of value and a refined kitchen lifestyle. As demonstrated at Milan Design Week, and at other major exhibitions around the world, LG is committed to partnering with like-minded innovators who share its passion for pushing boundaries and elevating everyday life.
Stay tuned to
link hidden, please login to view for the latest stories and updates on LG’s exciting collaborations. # # #
