By
atcronin
LPT
Hi.
When Im playing a movie in an app on my LG OLED TV the screen is turned off after 15 minutter and only showing for the lack of other words its "digital fireworks» and the text "Turn on screen by pressing any button on remote except power button».
Its really annoying.
Every power/eco mode is off and no timer is active?
Anyone?
