LG 77C9 TV settings not holding
By Low Grade
many thanks in advance😃
By Magsing
By Itachi3431
Hi all,
P.S., running latest Web OS
By LG user1
I can't open settings on my LG B9 55" either from the remote (results in black screen) or from menu system (same). Also, when I click on any streaming app, nothing happens although the buttons on the remote otherwise work. I would like to try a factory reset, but can't do this without accessing the system menu. If you know how to factory reset without the menu or otherwise know a fix, please let me know!
By pattox
It is easy to add a new item to the quick settings side menu on an lg c2, as long as the item you want is shown on the list presented when you choose the + add item. If you want to add a "shortcut" to an item that is not on the list then how can that be done. Is it possible to edit the list presented?
Specifically I want to add a shortcut to "subtitles on" which is buried deep in accessibility settings, there nothing on the list of options presented to allow this.
lambrkt
Has anyone else run into this? In an effort to get clear dialog over the constant background music on today's TV shows so loud you can't hear the actors, I change d the sound out setting to internal speakers+ optical out to my Denon X4400H which is set up 7.1. Big improvement!! The issue - when I turn the TV off via the remote, the Denon shuts off as well which is OK. When I turn the TV back on the sound out setting has reset to internal tv speakers and I have to go back and re-enable . Also, when I first changed the sound out to internal+optical the Denon came on as well. Now I have to turn it on manually. When I shut the TV off, the Denon still goes off as well. Has anyone else run into this?
