After latest update sound reverts from Hdmi Arc to internal speakers . I holds for awhile after I change it but eventually it reverts back to internal speakers. It only just started after software update 4.30.10 . Tv is Oled55cxaua
    • By OliverRC
    • By Ajothen
    • By atcronin
    • By Batman
