How do I get to the LG plex app settings
By DavidSr
By Cody94549
By Low Grade
many thanks in advance😃
By Magsing
By Itachi3431
Hi all,
P.S., running latest Web OS
Jason Worthen
I need to set my plex app settings to allow insecure connections. and I have tried everything to find a menu to the plex app settings. But I cant seam to find a way there.
