Can I record a program when I am not watching it
Hi have a lg50up77006lb TV I have a usb stick plugged in when iset a program to record  and  when watching another program the TV changes channel to the program I am recording  and when I change it back to what I was watching it stops recording  am I doing anything wrong
Unfortunately my LG smart TV (OLED65C8PTA) does NOT allow you to change the TV channel once recording has started. It warns me that recording will STOP if I change channels.
It is good if you are going to bed or going out, and will not be present when the recording happens.
To have this functionality you would need a twin tuner setup. Which Tv's don't generally have.
There might be dedicated devices which allow this. DVD recorders etc...
    • By JasonB
    • By Peter_T
    • By wallyricks
    • By JamieG
    • By Nick Payne
