password saving on WEB OS
By agus
By JayDee
With so few apps available, I find the need to use the janky included browser. It's bad enough but having to type in my account AND password every time? I love that the apps I *can* download work great -- even when I'm at the end of my data plan and everything is hampered by the slower speed!
You'd think something called "WebOS" would work with.. the web... a little more reliably. Let us download JioPages, OpenBrowser, SOMETHING that makes our TVs easier to use.
By nester
it would be great if there was some kind of “percentage” slider or just adjusted power saving settings. Right now, there is too much difference between maximum and medium power saving mode - maximum is too dark and medium is too bright, with no way to be set between. Also difference between two brightest is not so much big.
Second idea is to bring this setting somewhere closer (higher) in options. In my opinion, it might be the often changed setting by users. I use to change it regularly, especially between day and night.
By chupo_cro
I have LB650V webOS TV and it is very annoying having to reselect the (Latin 2) subtitle encoding (Code Page) every time when playing the movie. Absolutely no excuse not to save the last used choice for the subtitle Code Page so I hope it will be implemented in the future firmware updates.
And one more thing about the subtitles: the options to turn on the transparent background and/or the character outlines has to be done - to improve the readability.
By Francisco Estrada
I have the LG WP401 webOS Box model, to configure it, the previous administrator gave it a password and it did not leave it for me.
How can I give it a factory reset or change the current password to be able to enter via the Web, to use the content manager and control manager
Thanks for the help
