Keep getting error when trying to accept agreements
By JasonB
By Hasan Ghasabi-Oskoei
Can you help?
By Marko00
only with cancel button.
How to fix it?
By leader6234
Hey guys !!!
Thanks in advance !!!
By Muser
DaniS
I reset my location which in turn made me have to accept the terms and conditions however every time I try to load them it tells me I have to download them to which I say okay but then it tells me there’s an error and I can’t download them. I haven’t been able to use my apps or anything for two hours. I reset by tv completely and it still won’t let me. Pls help
