Disable voice "help" when choosing a channel
When I use voice recognition to say, e.g., "watch PBS", I get a string of channels across the bottom and a very loud voice telling me that it has found channels. I want that voice to go away. Note that I have disabled Audio Guidance in the Accessibility Settings. This is on a OLED55CXAUA.
Thanks.
    • By mycop
      Greetings.
    • By Calvinder
      One suggestion was to go to Settings>all settings>general>AI Service>Voice recognition service and change to LG ThinQ.
      But the  Voice recognition service tab is gone. There is only voice recognition settings tab
      I would rather not have to reset to factory settings unless there is a way to save / export my current seating's
      Any suggestions
    • By John Nguyen
    • By Rizwan Sumra
    • By Peter Payne
