Static on all inputs, menus unaffected - 55UF7600-UJ
While watching the TV, lines appeared on the screen with some static. This persisted briefly, then the entire picture went to static. This same static is visible on all inputs, from apps to live TV, HDMI, etc.
Sound is fine, menus are unaffected.
So far I have tried power cycling, factory reset, disconnecting all cables, and trying different picture settings, to no avail.  I suspect some kind of hardware issue. Any tips gladly appreciated.
Edit: I have a replacement EBT63990603 mainboard on order, hopefully that solves it. I see some people have attempted to reflow the solder on the processors to fix these, seems like a dice roll.
    • By DW1
    • By pingber
      All of a sudden, the row of inputs showed up at the bottom of the home screen on my C1. I’ve tried every setting but can’t seem to get rid of them. I used to just call them up as needed (input button on remote) but now they’re there permanently. Any ideas?
    • By Alley Cat
      I am currently using this TV only to view internet content.  I am using the built-in wifi and ethernet connections.  But the TV starts up into maximally loud static every time and I haven't found a way around this.  Just about anything else would be better.  It could autodetect and mute the static.  Or it could start into the Apps screen.  Or it could start into my preferred app.  Or it could just start into a blank screen.  Whatever.  Just not loud, loud static.
      I read someone was able to set parental controls to get rid of the cable channels so it didn't start into static but that didn't work for me -- I deleted and locked all static channels but it still starts up into one of them.
      I guess more people have had success giving it an HDMI input and setting that as default -- I can't find the menu item to do that, maybe I need to actually connect an HDMI input? I don't have one readily available.  It seems silly to spend money on an extra streaming box to mostly do things that are built into my $900 TV, because it was designed to blast static on my speakers every time it starts up.
      So -- are there any other possibilities to solve this problem?
    • By Brendanchatt
      Hello all,
      From what I can tell, this may not be supported anymore.  I am on webOS TV Version 7.1.0-68 (mullet-maria).
      I just purchased an OLED 42 inch C2.  When I select Multiview, the two hdmi ports are not an available combination.
      I have turned of CEC (now SIMPLINK) for both HDMI inputs as I read in a post from 2018.
      Thank you,
      Brendan
    • By Alexandre
      Is there a way we could rename the HDMI INPUTS ? For example, I have a Fire TV attached to my HDMI1 and a Chromecast plugged to my HDMI 3. I wish I could be able to see the device names, instead of just having to guess which gadget is attached to each port. Please help !!!
