TV apps stopped working, remote pointer missing and WiFi inoperative
By NickL
Br,
Nick
By thewookiewon
By agus
By Roy Brown
Nath8884
Good evening.
I have a LG 43UK6950PLB, a few years old.
Suddenly yesterday most things stopped working.
The apps just freeze and won't load,
The remote cursor has disappeared,
If selecting a different input, it won't load that input and just freezes.
Wifi isn't connected, however it can find my router in the menu, just won't connect.
I've carried out a reset, unplugging, and turning off standby mode etc to no avail.
Any help appreciated, thank you.
