Problem with interlaced resolution
By PVD
By hollean
By AJO
By BozaB
I need help, I bought LG Oled 65 C41 LA tv two days ago, tv is working mostly fine, except when I watch LG installed streaming platforms ( Netflix and MAX tested ) tv freezes and after about 10 seconds it restarts. It does not have any pattern as far as I know, sometimes I can watch 20 mins, last two times after six minutes it crashed and restarted automatically. Can someone please help me, how can I resolve this issue? Did someone had sam problems already? Is my tv broken or I can do something to fix it?
By DeJaVu
- 0 replies
- 2,240 views
- 5,826 views
- 2 answers
- 14,937 views
Jasmin Rašljanin
I recently bought a UHD tv 65UP75003. I'm not sure, but I think there was a problem after the software upgrade. The TV is connected via an HDMI cable to a DTV receiver that sends 1080i resolution and the problem is in the horizontal line that travels from top to bottom. The line is not visible at progressive resolution. What I did: Reset the TV, receiver, bought a new high speed HDMI cable ...
Please help and what to try next?
