GX 77 switches to HDMI port 1 on it's own?
Hi Guys,
My 2020 GX 77" keeps switching itself to HDMI port 1 all on it's own.
I can prevent it from doing so by disabling the SIMPLINK, but if I do that....my LG soundbar no longer works.
I tried toggling the auto device detection & quickstart. Any suggestions?
I read some posts that infer that it could be the motherboard?
Thanks in advance!
-Harry
    • By Kane Murphy
    • By starwoodtech
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By jikhead
      I'm not getting any audio from the apps via the HDMI via ARC connection to my receiver.  This occurred two weeks ago and was unable to resolve it, but ironically there was new firmware released that same day for my B6 (3/31/17) and this fixed the issue.  However, now I again can't get it working after a TV reset and tinkering with the audio settings again.  I tried to load the firmware again, but it appears this is not possible to forceable load the same firmware.
    • Solution For That Pollution
    • By BGee
      On my LG 60SJ850T, Watching Horizon from AppleTV streaming service. Western with some scenes with Apache language being spoken. No subtitles appearing. When CC is on, see “foreign language being spoken”. When viewed on iPhone, there are subtitles. Have tried same movie using chrome cast TV, and casting from iPhone to Apple TV device. Never get subtitles. Verified subtitles work when I stream to same chromecast TV connected to a different TV.
      reset LG TV to factory settings after trying all available CC and subtitle settings on TV. Still no subtitles.
