App Review: Couch to 5K
One of the biggest challenges facing us for
is just getting our behinds up off the couch and exercising. Be it doing pushups during commercial breaks of going out for a run, getting off that couch is the first step. But what's step #2? That's what Infinite Appz's so aptly-named aims to answer.
Couch to 5K provides a three-days-a-week for nine weeks program designed to get your from nothing to being able to run a full five kilometers (3.1 miles) nonstop. Sound impossible to do in just nine weeks? It's not as hard as you might think, and the simplicity of Couch to 5K will make it easier.
The app provides a evolving routine each day, starting with twenty minutes of alternating between jogging and walking on week one, day one to twenty minutes of jogging on day three of week five, finishing with a 30 minute jog set at the end of the nine week course. You're presented with a basic and linear interface that updates with the new day's course (assuming you finish the previous one) with a big countdown time in the center with a Start/Pause/Resume button below.
Hit Start and you're prompted by a disembodied male voice with a neutral American accent to begin your warm-up with a five minute countdown. Once the initial warm-up countdown concludes, Couch to 5K automatically moves to the next stage of the day's workout: "Jog Now." For the first few weeks you'll alternate between jogging and walking, with the voice offering audible prompts as you go. As you progress through the program the jog periods grow longer and the walks shorter and less frequent, until you reach the point where you're just running non-stop. Which is the goal, no?
a2t.img2_AdCWkdq6E
    • By Alex
      the viewer sits.
      Source:
      Video calling from the couch is coming to LG TV owners thanks to a firmware upgrade that optimizes the interface on LG TVs to access
      link hidden, please login to view.* Rolling out worldwide on LG Smart TVs with webOS version 6.0, the firmware offers more convenience for LG TV owners when connecting and using Portal TV to keep in close contact with family, friends, even coworkers.
      LG TV users will benefit from Portal TV’s smooth integration that includes extremely easy setup and LG Magic Remote compatibility. Initial setup is hassle-free, requiring only plugging the Portal TV HDMI cable into the LG Smart TV. The Portal TV device will be detected immediately and display a pop-up notice on the screen, providing quick access from the webOS home screen or Home Dashboard. Video call functionality can be controlled directly from the LG Magic Remote, its four-directional keys acting as command keys allowing users to control it similarly as the dedicated Portal TV remote control.
      Photo Credit:
      Once connected, users can make video calls to family and friends on Messenger and WhatsApp. Portal TV also supports Messenger Rooms, as well as Zoom, Workplace and GoToMeeting, which are useful when working from home. Portal TV also features Story Time, which brings stories to life during video calls with animations, music and AR effects.
      Photo Credit:
      Portal’s Smart Camera automatically pans and zooms so users can talk and move freely. Smart Camera widens the view automatically when a new participant steps into the frame. Smart Sound enhances the speaker’s voice during video calls while minimizing background noise.
      Portal was created with privacy, safety and security in mind with clear and simple settings, so users stay in control. When not in use, LG TV owners can disable the camera and microphone on Portal with the sliding switch. A red light on the front of Portal TV indicates when the microphone and camera are turned off. Users can also use the included camera cover to block Portal TV’s camera when not in use.
      * Portal TV from Facebook is a separate purchase from LG TV.
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
        Q10 in 90 minutes
