please permanently save custom input labels, even after HDMI cable is disconnected
On my LG 49UN71 my custom input title and icon resets if I ever disconnect the HDMI cable. Can you make it so this doesn't change regardless what happens to the actual connection? See this post for more info:
  • 3 weeks later...
    • By OliverRC
    • By atcronin
    • By mean2
    • By Batman
