Android Settings App?
Hi there! There is a Settings app on Android devices that provides access to various system settings and preferences. It's a built-in app that comes pre-installed on Android devices and is accessible from the app drawer or the quick settings panel. As far as I know, the Settings app is a central location for managing various aspects of an Android device. It provides users with a way to personalize and customize their device to meet their needs and preferences. But I'm not a pro. So, if you need more info, I recommend you to address reliable app developers, such as those from
Hope I helped!
    • By Cody94549
    • By Low Grade
      many thanks in advance😃
    • By Magsing
    • By Itachi3431
      Hi all,
      TV details - 4K Ultra HD Smart LED TV 55UR7500PSC
      P.S., running latest Web OS
    • By LG user1
      I can't open settings on my LG B9 55" either from the remote (results in black screen) or from menu system (same). Also, when I click on any streaming app, nothing happens although the buttons on the remote otherwise work. I would like to try a factory reset, but can't do this without accessing the system menu. If you know how to factory reset without the menu or otherwise know a fix, please let me know!
