By andreluigo
I used to extend my screen from PC/Notebook to my TV but i stayed a long period without do it.
It happens that since a few days ago i am needing it and for my surprise is not working anymore. Tried other cables, updated the drivers and O.S. but nothing worked. So i decided test at the room's TV (LG as well) and worked perfetcly.
I looked for all internet and youtube for similar issues and a solution but couldn't find it, until i receive my weekly mail from this forum and remembered it.
I am suspicious that was one of the several updates since i extended for the last time that made this!
So, does anybody could help me, please?
Thanks in advance!
By Marco Coletti
See topic title. I have an Android box connected to HDMI 1 and would like to check if it auto switches frame rate according to the current video file.
Is there any "secret code"?
OLED48CX3LB with webOS 5.4.3-36 fw 04.41.45
By Costin Angelescu
Good afternoon,
I have a 49UB850V-ZD smart TV and has the issues below. Can't understand if its a software issue or components issues:
1. Can't reset using meniu. I can access the meniu, I inserted pin 0000 and if I try to click Confirm it just flashes the button with no success. If I click Cancel then the meniu closes
2. The Live TV channels are not working. There is no issue with the provider. It just not plays any channel
3. If I connect the usb or hard-disk driver to play some movies I can navigate thru folder but I can t play any
4. When I connect to Netflix or youtube I can navigate but if i try to play it does not load.
5. The remote TV does not work anymore -> Only the Power Off/On button
6. I have a magic remote TV for LG and works to navigate with the indicator
7. The button of the TV (under the TV led) works only to open the TV -> the menu does not work anymore
8. In the advanced menu, the Channel settings is not active among other options that are disabled.
9. When I try to access the LG STORE it says: loading unsuccessful (82) because the hour of the TV is not the correct one. I tryed to change time to something different and also changed location and removed the location. This change did not had any effect
What do you think? What do I need to do?
By M55
I am trying to setup my new Phonak my hearing aids TV Connector with my new LG GP2 TV and Sonos Arc sound bar, connected by via the HDMI eArc port. The TV automatically uses the the HDMI eArc port, and that port only. As a result no signal goes through the optical out port of the LG TV.
Is there a way to make the LG TV sound signal simultaneously go out to both the sonud bar via eArc port and to the Phak TV Connector via the optical out port so that I can connect hearing aids to the Phonak TV connector and also use the Sonos Arc soundbar at the same time?
Appreciate any guidance.
Thanks, M55
By Hg-07
Hi!
Does anyone know how to select only a specific art collection as the screensaver? It seems you can select one or more to play manually, but the screensaver that comes on when there is no signal appears to automatically play all of them even if you have set it to play specific ones manually. Moreover you cannot delete the default ones either... I just want a specific theme not a hodgepodge of random works that LG considers "masterpieces"...
Popup messages: Wired Lan cable disconnected / Wired network is connected 1 2 3 4 7
By John Bizeray,
- 204 replies
- 229,555 views
- 10 answers
- 17,997 views
Brendan Cameron
I am forced to manually change the Input of My LG Oled TV to Apple TV because as we all know SimpLink is a lousy engineering with a failure rate of >95%. I am confronted with a very large and ugly pop up informing me of no signal and inexplicably questioning me about my Audio Settings. I being forced to manually dismiss it bores me and tots uglinesses offends me .
A second and appropriately designed “No Signal” message then floats along the bottom of my screen a few seconds later.
How do I rid my lovely OLED TV of this needless Pop Up?
