PreCentral: Make a Skype Video Call using the Phone & Video Calls app [webOS 3.0.5]
This tip is only for TouchPad's running webOS 3.0.5 and higher
TouchPad Video CallsWith the latest webOS 3.0.5 update for the TouchPad, it is easy to determine which of your Skype contacts are available for a video call directly from the Phone & Video Calls app and then quickly initiate that call. Once within the Phone & Video Calls app, switch to the "Video" tab on the top of the page. If you are not already logged in to Skype, you will be prompted to "Sign In". Otherwise, you will see a list of all your contacts that are able to accept video calls and you just need to tap on one to call them.
If you want to log off of Skype once you are done with your video calls, you can not actually do that from within the Phone & Video Calls app. You actually need to
a2t.imgZJ8X_leu5EE
    • By hollean
    • By murastefano
      How to show video cover art on  SmartShare on WebOS ?
      I have many movies, mp4 or mkv file with cover art muxed,  but SmartShare
    • By JamieG
    • By Call Me
      0822-46435524 . Layanan ini tersedia 24 jam, jadi kamu bisa menghubungi mereka kapan saja, baik melalui telepon rumah maupun handphone
      0822-4643-5524. Layanan ini tersedia 24 jam, jadi kamu bisa menghubungi mereka kapan saja, baik melalui telepon rumah maupun handphone
    • By leodavid
      I've recently purchased a WebOS TV UK6400PVC and magic remote came with it. The software version is 4.10.30.
      The buttons work fine but for some reason, I can't get the cursor to appear on screen.
      Appreciate the help. Thanks
