Missing Move Button for TV Stations in Programmes Manager
Hi, I cannot move TV Stations in an order of my desire since there is no option for that on my webOS  04.75.09. The webOS is up to date with it's updates.
Is there any way to accomplish what I a looking for or I am stuck with the default list of TV Stations provided by my Cable Provider?
Hi, yes. When you set up the channel list, do not choose your provider as the source, choose, "Other", then it will appear all the channels provided.
  • Thanks 1
    • By thewookiewon
    • By David Daul
    • By Dennis Radliff
    • By JamieG
    • By JonoW
