Trying to cast from my phone !
C89FE815-1065-4ABE-83DC-E4EAEC361096.thumb.png.88a48c35520ac99648d88e1f14985028.pngI’m trying to cast from an app on my phone to LG QLED but the app on my phone is telling me that (recording is prohibited,video stopped because TV output is ON or device is recording . Please disconnect TV Output or stop recording and try again) I really have no clue about this issue and what to do !
@lgsmart tv. @Support Mycloud
Any help guys
    • By JasonB
    • By Ramya Shyam
    • By Low Grade
      i thought of using my handphone to act as a remote control for the TV.............but it will only work with WiFi ??!!
      i had BlueTooth still turned on..............TV is using LAN connection only.........and the phone can no longer control the TV (the phone can control the TV with WiFi on)............is this normal ??
      many thanks in advance............
    • By Dimmy
      All of a sudden I am unable to cast from my Windows 11 laptop to my OLED65CX TV. The only option given to me is to cancel the request. I've previous been able to cast without issues.
      Any fixes for this issue? Useless LG support agent told me to just use an HDMI cable and kept referring to the TV as a 'monitor'.
    • By Ethan Miller
      Is there a way to fix this? There's a Samsung smart tv in my household that windows 7 recognizes and can cast to, but the LG WEBOS OLED TV is not even discoverable on the network and it is connected to WiFi. I know this tv is connected because in order to use AirPlay you have to be on the same WiFi. All my devices use the same WiFi connection. I can see all my devices except for the LG TV.
