I have LG 65C1,  Denon x4300h(arc monitor 1 was broken, but monitor 2 is working ),
and what I would like to know is,
can LG TV's autopower sync works?
I mean I want to turn on TV using  the LG remote control,
then my Denon x4300h could turn on automatically,
when I turn off TV, then Denon turn off automatically.
I tried many ways to test it, I open all the functions about hdmi control, hdmi cec, simplink, autopower sync...
but it still doesn't work,
how could I solve it?
Or LG TV  just can't do it?
Thanks a lot!
    • By informatiko
    • By Kane Murphy
    • By Diaa237
      How can i do right click on my LG smart TV by my magic remote?
    • By mortel
      Hello
      Modele : TV LG OLED65C15LA
      Firmware : 03.41.00
      WebOS : 6.4.0-21
      i'm french , i can't deactivate function "TV Rating Lock" , access by General > System > Safety
      (i change language form french to english before photo)
      i see on video it  possible
    • By Flavio_S
