WiFi issues, drops continuously and sometimes switchs off
Recently moved my 49SJ810V to another room where I can no longer cable to the router. It takes nearly 10mins for the WiFi search to find anything. Then sometimes fails to connect with correct login details. Then when it does it drops continuously and never stays for more than a few mins at at time. It even switches of the WiFi altogether!! Everything in my house connects fine and I've even got an even older LG up stairs that needs a WiFi dongle and I've just tried that and it works fine. Looks to me like its the software that is the issue. It has the latest  version installed.  I've done all that's recommended on the LG website. Any ideas?
I had a similar issue started occur recently with Wi-Fi dropping out, streaming media buffering (I'm on FTTP so shouldn't have been) then after a few days it started switching Wi-Fi off altogether and wouldn't turn back on at all.
I powered off at the plug for 5 minutes, Wi-Fi was fine for 2-3 minutes then dropped and switched off, when switching back on it just wasn't seeing my access point at all.
I factory reset, Wi-Fi was okay, reinstalled apps, halfway through logging into them all, Wi-Fi dropped again. Can't reconnect to it.
I started looking at new TV's from Richer Sounds, and was on the verge of purchasing a slightly larger model when I thought I'd have a look at replacing the network card.
Then...I found a YouTube video that instructed the following:
  1. Go to Settings
  2. General
  3. Location
  4. LG Services Location
  5. Select another country (it will warn you about losing access to certain services, accept this and TV will reboot)
  6. Go back to the same menu
  7. DISABLE the setting at the top, either called 'Automatically Detect' or 'Set Automatically'
  8. Reselect your correct Country in the list
  9. TV will reboot again
  10. RESULT! Do not re-enable that Detect Automatically setting - this seems to be a very weird bug where that setting is causing the network card to drop out.
Since doing this - no more buffering, no more Wi-Fi dropping or disabling itself, and everything is perfect.
Hope this helps you as it did me!
    • By agus
    • By akhil7j
    • By Tunari
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
      At Frieze London 2024, LG OLED and Akomfrah Bring Art and Technology
      Together to Inspire Audiences With a Thought-Provoking Film Installation
      SEOUL, Oct. 11, 2024 — LG Electronics (LG) has once again partnered with the widely respected artist and filmmaker, Sir John Akomfrah, for Frieze London 2024. This collaboration follows LG’s recent support of Akomfrah’s British Pavilion at the 60th International Art Exhibition at La Biennale di Venezia 2024. At Frieze London 2024, LG OLED has invited Akomfrah – an artist and filmmaker known for investigating themes such as memory, post-colonialism, temporality and aesthetics – to present a new video installation at the fair.
      Becoming Wind (2023) is a five-channel video installation that focuses on the intersection of social and environmental issues, looking specifically at the experience of non-binary and trans actors and activists in the context of the climate crisis. A profound meditation on identity formation is framed by an allegorical representation of the Garden of Eden and its disappearance; a montage of footage evoking the abundant richness of past biodiversity is interrupted by glimpses of blazing wildfires, scenes of racial discrimination and a fragmented text, underscoring responsibilities to confront multiple and intersecting crises.
      Powered by the compelling fusion of art and technology, multiple ultra-large LG OLED displays bring Akomfrah’s artistic narratives to life with stunning picture quality on an incredible scale. Notably, LG OLED’s self-lit nature reveals the full, vivid expression of the colors, enriching the depth and realism of the artwork’s multi-sensory elements for a truly immersive experience.
      LG’s commitment to making LG OLED a more sustainable choice closely aligns with Akomfrah’s drive to address climate change, human communities and the plight of migrant diasporas globally. LG OLED TVs incorporate fewer components than LCD TVs due to the absence of a backlight, which results in the 65-inch OLED TV using 60 percent less plastic compared to an LCD TV of the same size. Weighing in at about 20 percent less than an LCD TV of the same screen size, OLED screens also contribute to the reduction of CO2 emissions during transit. In addition, recycled plastic accounts for approximately 20 percent of the plastic used in the manufacturing of all LG TVs, including OLED models. These efforts have culminated in LG OLED TVs receiving environmental product certifications from the UK’s Carbon Trust and Switzerland’s SGS for four consecutive years, underscoring the company’s commitment to sustainability.*
      “I’m truly delighted to be able to bring my artistic vision to life with LG OLED,” said Akomfrah. “Becoming Wind aims to draw viewers into a deep state of contemplation about the intrinsic relationship between nature, humanity and technology through the interplay between sound and visuals. LG OLED’s advanced audiovisual capabilities and technological advancements enhance the sensory elements of the art, seamlessly integrating image, sound and emotion to take audiences on a visually compelling and intellectually stimulating journey.”
      “We are pleased to continue our collaboration with renowned artist Sir John Akomfrah to highlight how LG OLED captivates audiences by enhancing the depth of his thought-provoking artwork,” said Kate Oh, vice president of the Brand Communication Division at LG Home Entertainment Company. “LG OLED remains committed to supporting both artists and audiences who embrace our passion for innovation and positive change. We will continue to empower artists who seek to inspire the world through the intersection of art and technology.
      Visitors to Frieze London 2024 can experience Akomfrah’s artwork Becoming Wind from October 9 to 13 at The Regent’s Park. Visit the
      link hidden, please login to view to step into a world of artistic brilliance and explore captivating collaborations with LG OLED ART. # # #
      * Carbon Trust: Carbon Footprint Reducing certifications (2024 LG OLED evo G4 77”/65”/55”)
      Carbon Footprint Measured certifications (2024 LG OLED evo G4 97”/83”, C4)
      SGS: Environmentally Evaluated certifications (2024 LG OLED evo G4/C4/B4)
