CANNOT LOGIN LG
By Andreas Boyatzoglou
Model: OLED55BX3LB
Viewing videos from
link hidden, please login to view was fine up to about one month ago. I do not know if there was an upgrade, but videos from that site cannot be played any longer on this tv. From the same wifi network (home network) videos from that site play fine to a number of devices (Android phones, 2 win11 laptops, 1 win10 laptop).
By Justin Bester
By Joe C
By starwoodtech
By Peter Steinmeijer
Is my TV too old ?
ABE
Hi, i've bought LG smart TV UP7750 4k UHD tv. All are ok. But I can't sign in my lg account in the tv. When I'm going to sign in my lg account in the tv it shows "Temporary server error has occurred. Pls try again later." pls do anyone know solution?
