By
atcronin
Bgundling
Anyone else experiencing this? With an app open, if I hit the home button and return to the Home Screen that app relaunches on its own within a few seconds. The two that I have experienced this with so far are Disney+ and LG Channels. I saw a post where users were experiencing this with Sling and had no resolution to the problem. WebOS version number 03.25.11. It is very annoying and makes the experience using WebOS horrible.
