LG 65A16LA 2021 wifi error 2.4Ghz
By agus
By Marko00
only with cancel button.
How to fix it?
By leader6234
Hey guys !!!
Thanks in advance !!!
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
Shaggy men
Hi all!
I am trying to connect the TV to my 2.4Ghz wifi because I have a Google Home mini and some smart lamps that only work on that 2.4Ghz frequency. This would ensure that everything was on the same network.
When I configure the tv to connect to the 2.4Ghz wifi, always gives me an error that it could not connect to the network. If I try to connect to the 5Ghz network (with a different name than the 2.4Ghz) it connects without problems. If I connect the cable tv it works too. All home devices that connect to the 2.4Ghz network are working fine.
Any solution to something that should be so simple?
