Remote control and sound bar.
By RJ Fischer
By Pranay Mokida
By Regis Wheeler
By JasonB
- 696 views
- 0 replies
- 743 views
- 1 answer
- 3,133 views
LG 65C12LA and sound output device (eARC)
- soundbar
- headphones
- (and 1 more)
- 2 answers
- 1,743 views
Angel Beagle
How do I make my LG TV remote controller quit controlling my Vizio soundbar.
Sent from my iPad using Tapatalk
